Results 1 to 11 of 11
    Veteran Member Four Rings m5racer's Avatar
    Nov 20 2006
    Power Gasket Plus - Any Good?
    Came across this. Looks intresting. anyone used this before or know anything about it? Its from ecs? Any help would be great!
    Made from a high performance polymer Power Gasket™ conducts on average less than 1/500th of the heat of the steel gasket that it replaces. Your intake manifold will stay 30-50° F cooler and your incoming air will stay 20-30° F cooler.Power Gasket™ has been designed for affordability easy installation and no disruption to your manifold attachment and engine accessories. This means that you can simply swap your old intake manifold gasket for a Power Gasket. No buying longer bolts or installing multiple gaskets. In less than 2 hours you will be enjoying a more powerful better performing ride.NOTE: Does not fit Audi AEB Engines $54.99
    01.5 A4 1.8t sport
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: Power Gasket Plus - Any Good?
    i think mike runs something similar as well as a few others
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Combine that with water/meth injection and you can have some mighty cold air blowing through your engine (especially in the winter :-) )
    Veteran Member Four Rings fred2ka4's Avatar
    Nov 26 2005
    Audi A4, Honda Pilot
    NM
    I installed this when I did my EF conversion and the car did drop a few degrees in operating temperature but I could not tell you if it improved performance as I did not do a before or after dyno.
    BetaAlphaTau member #18
    2000 Audi A4 w/ APR stage III & ...
    APR // GReddy // RACETEC // Bilstein // IForged // ECS Tuning // STaSIS // Neuspeed // H&R //
    And a whole bunch of other stuff ...
    http://i78.photobucket.com/albums/j9...4/fredscar.jpg
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Yes I run one. It does keep the IAT's from creeping up as quickly and the IAT's come down much quicker.
    Veteran Member Four Rings Jibberific's Avatar
    May 21 2008
    az
    why won't it work on the AEB?
    {99.5 Avant}
    Dec 05 2007
    CA LA
    probably port size.
    the AEB has biger ports then the rest of the 1.8t engines
    Oct 01 2008
    Philly
    I run the 034 motorsports spacer, which is the thickest one on the market and it works great. IM is dead cold after i pop the hood. And they are available in small port, big port (AEB), and transition (big port to small port/vise versa)
    Jul 07 2004
    socal
    Quote Originally Posted by Jibberific View Post
    They make one for the large port(ndbw) and another one for the small port(dbw).
    May 21 2008
    az
    cool, i will probably get one of these pretty soon. i was thinking about getting the really thick 034 spacer, but i didn't want to screw up my cruise control.
    {99.5 Avant}
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    I have one on mine and the intake mani is much cooler to the touch.
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
