Results 1 to 7 of 7
    Established Member Two Rings jimmyjamm's Avatar
    Jan 16 2006
    Winter Tire Pressures same as Summer Tires??
    Hi,
    Just got a set of 17" Nokian R winter tires and was wondering if they should be inflated to the same PSI as the standard 18" rubber. If memory serves the manual recommends for the 18" setup 38psi for the fronts and 35 to 42psi for the rears.
    My car is an 07 Avant Sline. Anyone know for sure?
    Jul 30 2008
    08 Passat 2.0t
    Near Mountain Creek
    Re: Winter Tire Pressures same as Summer Tires??
    yes.
    08 Passat wagon 2.0T 6MT (APR Stage I, DriverGear-Eibach springs, Bilstein Sport, Euro smoked tails, intake, ATE Premium One rotors, Hawk HPS, Tyrolsport Caliper Guide Bushings, other stuff)
    Previous Cars:
    02 Golf TDI 5MT (Chipped, Bosio PP764 nozzles, VNT-17, Shine Racing suspension, S3 strut brace, WRD rear strut brace)
    88.5 Camry V6 5MT
    84 Corolla 3AT (the FWD version, hand-me-down)
    Veteran Member Four Rings s6sputnik's Avatar
    95 S6 rs2//13 A6 3.0T//12 S4
    Austin Texas
    Quote Originally Posted by UGwagen View Post
    yes.
    And I agree!!
    Shawn
    2222 & 620 Austin TX
    // 95 S6 RS2 // 13 A6 3.0T // 12 S4 3.0T
    Established Member Two Rings tquattro2004's Avatar
    May 11 2008
    2004 audi A6 2.7
    new jersey
    What tire pressure are you guys running on your a6's?
    I have mine at 34 all around is that too low? Could that be affecting my gas mlage?
    Anything higher and makes the handling feeling way off....
    Thanks
    Apr 18 2007
    ny
    I do 35 all around.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Veteran Member Three Rings 04A6SLine's Avatar
    Oct 16 2007
    Brooklyn NY
    35 all around.. you should see that little sticker on the side of the door. it'll tell you what PSI to put on.. but as for the winter tires,, i guess it's a bit different.
    Jan 16 2006
    Thanks for everyone's input. I need to check the manual again as I think the recommended PSI varies from 33 up to 38 depending on the number of passengers and luggage.
