Results 1 to 10 of 10
    Registered Member Two Rings
    Dec 18 2006
    Auburn, WA
    Can I run different size tires??
    So I bought a set of wheels with a high offset, and I put on my 245 35 19 tires. I get slight rubbing in the front when I go over bumps. So I found a set of 2 tires that are 225 35 19 and I want to put them on the front. They are new, along with my 245's.
    Would that be an issue? My car is Quattro.
    Veteran Member Four Rings D0lphinGrey's Avatar
    May 31 2007
    B7 2.0TQ S_line
    Sydney
    Re: Can I run different size tires??
    I have a similar question:
    my stock Dunlops are down to the wear indicator at the front and about 50% at the rear. I have a spare pair of Bridgestone S03s (near new) that I can replace the front Dunlops with.
    The specs are 225/45R17 91Y. Stock Dunlops are 235/45R17 94Y.
    Now is this a good idea? The 10mm difference in width wouldn't be a problem would it?
    Veteran Member Three Rings Kevin2772's Avatar
    Apr 17 2008
    Cincinnati
    I believe this CAN be ok, if the wheels have the SAME rolling diameter. But I would check with audi on this. I do know that rolling diameter is the most important factor.
    03 BMW M3 Convertible
    13 A4 2.0T 6MT Premium Plus (Gone)
    08 A4 2.0T 6MT S-Line Ti.Pkg / APR 93oct. Tune / Forge DV (gone)
    Jan 22 2006
    2006 B7 A4 s-line quartz grey
    socal
    No. If your car is quattro, your front tire size and rear tire size shouldn't deviate any more than 10mm.
    Veteran Member Four Rings retrohasen's Avatar
    Feb 12 2004
    strollers, trikes, bikes, etc.
    Alameda, CA
    all 4 tires have to be within 3% in rolling radius for Quattro and ABS, according to Audi.
    2002,2005,2008 Audi A4 Avants ALL SOLD
    1984 VW Rabbit Convertible 2.0l 16v 6-speed
    2003 Audi Allroad
    May 31 2007
    B7 2.0TQ S_line
    Sydney
    Quote Originally Posted by retrohasen View Post
    Thanks for all the replys.
    I ran it through this tire size calculator: http://www.1010tires.com/TireSizeCal...?action=submit
    It seems it's still within Audi's recommended range, the diameter difference is only 1.39%. What do you guys think?
    Stock Tire - 235/45R17
    Tire 1 - 225/45R17
    Section Width: 9.25 in 235 mm
    Section Width: 8.85 in 225 mm
    Rim Diameter: 17 in 431.8 mm
    Rim Width Range: 7.5 - 9 in
    Rim Width Range: 7 - 8.5 in
    Overall Diameter: 25.32 in 643.12 mm
    Overall Diameter: 24.97 in 634.23 mm
    Sidewall Height: 4.16 in 105.66 mm
    Sidewall Height: 3.98 in 101.09 mm
    Radius: 12.66 in 321.56 mm
    Radius: 12.48 in 316.99 mm
    Circumference: 79.54 in 2020.3 mm
    Circumference: 78.44 in 1992.3 mm
    Revs per Mile: 821.4
    Revs per Mile: 832.9
    Actual Speed: 60 mph 100 km/h
    Speedometer1: 60.8 mph 101. km/h
    Speedometer Difference: - Speedometer Difference: 1.400% too fast
    Diameter Difference: - Diameter Difference: 1.39%
    Veteran Member Four Rings bblume's Avatar
    Dec 20 2007
    06 avant. 92 Gti. 07 X3. 14 Sq5
    Colorado
    YES....this is just like being staggered
    The numbers that are different on the tires mentioned above
    are all measurements of width in mm.
    I'm fairly sure there are people running staggered setups without issue...
    as said before rolling diameter (heighth) and tread pattern should be similar
    if not identical...You don't want one wheel gripping differently than another
    or you may risk stressing quattro a bit.
    14 Sq5
    02 Eurovan
    04 DBP R32:.
    92 Gti-TDi 1Z (sold)
    06 AVANT S-line QMT6 (Just sold it!!)
    07 BMW X3 (given to the in-laws
    Veteran Member Four Rings nick71692's Avatar
    Jan 16 2008
    2010 S4, 2005 A4 USP, 2008 BMW 650I Conv. Sport, 2013 Jetta GLI
    Ohio and GTA
    The best size that looks good and doesnt rub is a 235/35 r19.
    2005 Dolphin Grey USP
    USP CLUB MEMBER #210
    2008 Ibis White S-Line A4 6mt, Stasis Exhaust (Gone)
    2010: S4, Ibis White, S-Tronic (Gone)
    2011 MKVI GTI 4 Door, Carbon, DSG (Gone)
    2012 S4, Monsoon Gray, 6MT (Gone)
    2014 S4, Glacier White - fully loaded (Gone)
    2019 S4, Glacier White - Prestige
    Oct 16 2008
    South Florida - Ft Lauderdale
    Quote Originally Posted by nick71692 View Post
    My setup:
    F 235/35/19
    R 265/30/19
    and no rubbing
    Registered Member Three Rings SGVA4's Avatar
    Mar 03 2008
    07 3.2 Quat SLine, 08 MKV SE
    626 SoCal
    My setup:
    F 235/35/19
    R 265/30/19
    and no rubbing
    Quattro?
    Work Euroline FS/Falken/Cupra R/HID yellow fogs/H&R/Eibach/Bilstein/Apexi/Optic Black RS4 Grill
    Hoen plate bulbs/ZiZa city lights/RS4 foglight grill coming soon!!!
    "J Spec B7"
