i've got an odd one. didn't find the same symptoms in any other threads.
basically after changing my oil the other day i had moved the coolant res so that i could get to the oil filter from the top, when i put it back i forgot to reconnect the sensor so i got a coolant warning. well i figured it out and plugged it back in and the warning went away. well i went somewhere yesterday and my heat woudl not warm up, it was warmer then outside but it was still quite chilly. the temp gauge went from cold to pointing exactly at the middle just like normal but the heat still never warmed up except very slightly when i brought it to 3.5k rpm after stopping at a stop sign. when i opened the hood there was gurgling noise, the coolant res had more in it then it did the night before (past max level now) and loosened the cap to release the pressure it just started spitting boiling coolant (not at me, don't worry).
so this is what i have:
no heat
boiling coolant
temp gauge shows normal operation
was just playing around under the hood (likely my fault it's not working)
due to the excess coolant and lake of heat i am assuming that the thermostat is stuck closed and that the second half of the coolant system is empty. why woudl my temp gauge read normal though and no cel's come on?
If anyone has any thoughts that woudl be cool, otherwise i'm going to order a new thermostat tomorrow.
