    Veteran Member Three Rings jayuuey's Avatar
    Aug 22 2007
    SF Bay Area
    tire rollover during hard cornering, autox related
    during autox, my tires are getting major rollover action. i chalk the tires to check how bad rollover is and i cannot dial in a tire pressure that will not result in ruining my sidewalls.
    car is lowered 26" fender to the ground on koni coils.
    typical tire pressure: fr, rr, 45, 38 respectively
    tires: BFG supersport A/S (no dedicated track wheels/tires, yet...)
    everything else in the suspension is stock. any experience or recommended alignment specs or tire pressure is appreciated.
    Thanks.
    Jay
    Current: Ibis White A4 Avant S-line TI 2.0T MT6 (JHM STS, Unitronic Stage1)
    Sold and quickly forgotten: 09 Forester XT Limited
    Sold and will be missed: A4 2.0T Quattro, 6-speed manual, APR Stage 2+
    (old) norcal audizine GTGs, etc. http://www.flickr.com/photos/jayuuey/sets/
    Registered Member Two Rings
    Jul 23 2008
    Auburn, AL
    Re: tire rollover during hard cornering, autox related
    Check your camber
    Nov 19 2005
    Pair of (. )( .)
    add more air?
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Established Member Two Rings BlueHand_Q's Avatar
    Dec 16 2007
    04 S4
    Chicago, IL
    Try this.....it's been working out great for me with Falken Azenis RT-615.....in cooler temps the 2 psi split would work better than when it's hot so, as the day and conditions get hotter the car set up needs to be adjusted ... when understeering you need to either raise the pressure in the front or lower the rear widening the gap to get the car to rotate better
    Feb 01 2008
    alot
    san jose
    have you changed your alignment? you can set it up better for autox then the factory specs.
    you should bring it over and I can set it up. (I run sfr events also. I usually co drive Tom Kubo's blue CSP miata)
    http://www.audizine.com/forum/showthread.php?t=261726
    Later,
    Scott Fraser
    www.Scott-Fraser.com
