Results 1 to 30 of 30
    Senior Member Two Rings sti4now's Avatar
    Oct 21 2008
    Turbo M3
    NC
    APR stage 3 ECU ?
    I have an APR chip for my APR fuel kit and APR K04's. I was wondering what the boost will be set to if I put in 100 oct and go to the RACE map mode. Just let me know thanks
    md
    Re: APR stage 3 ECU ?
    19-21 lbs.. apr's race file does not raise the boost..
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Quote Originally Posted by sti4now View Post
    omg, are you still going on about raising the boost?
    Oct 21 2008
    Turbo M3
    NC
    ^I was just wandering what all would be changed (timing, boost etc) I am new to the S4 world, so I would appreciate being informed rather than flamed.
    May 26 2008
    MD
    Ok thats fine. The race file will change timing more than boost. I seem to remember on MDS4 race file the boost actually drops but the timing increases.
    Oct 21 2008
    Turbo M3
    NC
    ^ was there a noticeable difference?
    May 26 2008
    MD
    O yea there is a noticable difference.
    md
    Quote Originally Posted by Evilevo View Post
    This is correct.. its not all about boooosttt !
    Senior Member Two Rings SpoolPastYou's Avatar
    Jul 15 2008
    Miami
    go VAST
    May 29 2004
    Calgary
    Thumbs down Re: APR stage 3 ECU ?
    ^Very useful...
    While Vast has great software.. you're APR stuff can run dare I say just as fast with a few lemmi-tweaks....
    Veteran Member Three Rings ms4cd's Avatar
    Mar 23 2005
    Slow buckets
    I love my APR stage 3 software. It put down some great numbers on a local dyno.
    I run 104 map with 100 octane and meth, works great.
    Oct 21 2008
    Turbo M3
    NC
    ^could I safely run the 104 map with 100oct? Also could I go VAST with APR fueling?
    ECS stage 3 S4, APR stg 3 fueling, APR K04 turbo kit, Iforged Aero 19" wheels, Reiger front bumper, ABT sides, Samco TBB, JHM FMIC, H&R coilovers, Porsche stage 4 cayenne BB kit, AWE DTS, RS4 Clutch, SS kit, FORGE DV's, JE design Heckspoiler, ECS shiftknob w. suede boot, VDO boost gauge
    01 Stage 3 S4, AWE turbos/fueling, H&R race springs, O.Z Superleggaro's, JHM FMIC, JHM solid SSK, SSAC TBE, Samco TBB, VAST stage 3 clutch, VDO boost gauge.
    md
    NO! you need 104 oct to run 104 or 100 oct and meth.. Vast does have a file to run rs4 injectors but you still need to change out the maf/housing and the fpr I think.. I think the total cost of the switch over was around 1500 iirc..
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Are you kidding?
    Can I put a square in a round hole?
    Oct 21 2008
    Turbo M3
    NC
    Can I run the race map with 93+ meth?
    Mar 23 2005
    Slow buckets
    No
    Sep 08 2008
    2K S4+79Merc300SD+65Barracuda
    Rohnert Park CA
    Im in progress(slowly) of going stage 3 from stage 2. Glad I didnt ask those questions.....although I'd just buy Xylene and add it to CA 91oct to boost enough to use 93file. I question if adding 45% or 1:2.5 would boost enough to run 100octfile.
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    Quote Originally Posted by ms4cd View Post
    No
    uh...yes. Meth combined with 93 makes OVER 105 octane. So tell me why a map for 104 wont work?
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    hey sti4now i have APR stage 3 too so feel free to ask me any questions. ill try my best not to flame u since youre a n00b ... but no promises
    heres some logs of pump file vs race file ...
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Sep 08 2008
    Rohnert Park CA
    [/QUOTE]
    What software do you use to graph those results. APR ECU Explorer? Looks like the only diff. is the timing. All other results are pretty close to being the same. Im looking to go stage 3 so any help would be great. I much rather plug n play.....not tweak or have a custom remapping. Perhaps you could part with some items.
    Nov 16 2006
    Boston
    yea ECUX ... and this really cool guy named MarkP on Audiworld made these macros and templates ... this other cool dude named nyet made this program called ecuxplot which is like an evolution on it.
    pretty cool huh?
    1999 Black A4 Avant
    Jun 14 2007
    2000 S4
    Connecticut
    I think you'd benefit from a custom tune from the way it sounds as you want more power. VAST can custom tune you based off of logs sent back etc etc. Free revisions for life with the fueling kit is pretty nice too
    Oct 21 2008
    Turbo M3
    NC
    I wish people could answer questions without flaming..Thank you DXC, much appreciated
    Mar 23 2005
    Slow buckets
    Quote Originally Posted by ///M3 TO S4 View Post
    Do you have the APR stage 3?
    I logged and found out that with 50/50 WM you CAN NOT run 100 map with 93 octane gas. Safely.
    If you do not give a shit you can do 87 with 104 map so I guess you were right. It is possible.
    Feb 09 2007
    Charlotte, NC
    100 is the MINIMUM octane for the 100 map, meth + 93 octane would be WELL over 100 octane....what's so hard to understand about that? And what logical explanation would cause it not to run right? If anything you should be able to tweak it for more timing. You obviously had something wrong with your car if you logged your car and still came up with that conclusion....
    Mar 23 2005
    Slow buckets
    Nothing wrong with my car. The timing CF's were way too high to run 100 map. That's all.
    Registered Member Two Rings
    Oct 24 2008
    Louisville, Ky
    I think you don't understand Water/Methanol injection and how it works. You are cooling the intake temperature, and altering the tendency to detonate somewhat. You are NOT raising octane to 100+, or producing an equivalent effect.
    Oct 21 2008
    Turbo M3
    NC
    Just talked to Chris at APR, and it CAN be done, just do some data logging to make sure the motor running efficiently without pings and knock. Could always run the 93 pump map with meth then throw in some 100+meth and run the race map
    Feb 13 2004
    stgIII b5 s4
    philly.
    hmm ive been spiking around 24 on my stage 3 apr. im still a bit confused on how everyone else is a bit lower.
    Oct 21 2008
    Turbo M3
    NC
    I spike around 23, but hold 19ish
