Results 1 to 4 of 4
    Dec 29 2005
    Columbus OH
    Steering rack boot
    Gang,
    How tough is it to replace the rubber boot (bellows) on the steering rack? My right side is leaking.
    Thanks,
    Ted
    Jul 10 2008
    CA
    Re: Steering rack boot
    I've done it. Both sides. Take a look at what you're about to do. There's no reason to disconnect any ball joints. Simply runout the tie-rods. Unlock the lock nuts on the tie rods and unscrew the rods from the tie rod ends.
    Dec 29 2005
    Columbus OH
    Thanks for the tip. Should there be fluid in the boots? Or is that a sign of a bad rack seal?
    Ted
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Quote Originally Posted by TZombek View Post
    Ted
    Correct, would be a sign of a leak.
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
