Results 1 to 4 of 4
    Senior Member Three Rings akarol's Avatar
    May 09 2008
    2003 Audi A4 3.0 Cabriolet
    Orlando, FL
    Question Headlights Oxidation Questions
    Well, I purchase Pittman's One Step Acrylic De-Oxidizer and it works just as advertised. However, I still notice some oxidation which seems to be coming from the inside of the headlights. Is that possible? If so, is there anyway I can remove just the plastic to clean it up? I heard that the unit is all one piece so it can't be snapped off.
    Thanks in advance...
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Re: Headlights Oxidation Questions
    youd have to heat the headlight wiht a heat gun around the seam of it. and then peal it apart... its actually a pretty decent size job and takes a while.
    look up DIY for "joey mod" and that will give you an idea of what to do.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Dec 06 2007
    u can split the housings using a heat gun and some ice picks but i wouldn't as they're vac sealed they will never seal the same again.
    And as for the oxidation stuff, just live with it as it is plastic and just like any other plastic it gets weathered over time.
    -Kirk
    BetaAlphaTau Member #58
    Established Member Two Rings sloweryucf's Avatar
    Feb 21 2008
    2003 A4 1.8T (sport package)
    Orlando, FL
    Where did you buy it, I can't find anything in google?
    GO KNIGHTS!
