Results 1 to 6 of 6
    Senior Member Two Rings p.tony's Avatar
    Sep 02 2007
    2000 s4 Stage 3, 1997 Lexus sc300 na-t, 2004 Touareg v8, 2007 Corvette
    Baltimore, MD
    Question stage 3 tuning dilemma
    in the process of a stage 3 build. I have unitronic, apr, and giac dealers in the area. I've also looked into vast but it's the inconvenience of mailing out the ecu. If they do a tweak to your file how is it applied via vag-com or mailing out the ecu again? Just looking for the most bang for the buck and some user feedback. Which tuning should i go with? Any additional suggestions? Thanks
    00 C5 2.7t //Stage 3//
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: stage 3 tuning dilemma
    Are you doing the install or a shop?
    08 S4- Stock SOLD
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    check out SSP. They are in NY and have the first and only A6 2.7T in the 11s. I know at some point he is coming down here again for my car. He also can set you up to do remote tuning.
    Sep 02 2007
    Baltimore, MD
    it's being done at a shop.
    Sep 02 2007
    Baltimore, MD
    Quote Originally Posted by Evilevo View Post
    remote tuning?
    Jun 14 2007
    2000 S4
    Connecticut
    check your PMs p.tony :)
