Results 1 to 18 of 18
    Established Member Two Rings Pestilaence's Avatar
    Nov 21 2008
    2004 Audi A4, 2003 Yamaha R6
    Bloomington, IN
    Front mesh grill... no opening latch?
    Hey guys! Brand new to the board! I've been browsing it for a few days, but finally registered the other day. Anyway, I did a bit of searching, and didn't really see an answer for this. How is it possible to have a full front mesh grill, and still be able to open the hood? I've seen a few pictures of people having a full grill with no opening for the hood latch. Is there something special that needs to be done to accomplish this?
    Also, I've seen a couple people have a pretty cool looking hood? It's one that goes over top of the headlights a little and has a much more aggressive look. Can anyone tell me what kind it is?
    Anyway, I'll be posting some pics of my A4 in the next day or so.
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    Re: Front mesh grill... no opening latch?
    the hood is called boser; usually carbon fiber.
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Nov 21 2008
    Bloomington, IN
    Awesome, thanks for the reply... does anyone know about the mesh grill??
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    Nov 21 2008
    Bloomington, IN
    Dec 06 2007
    u would have to run the latch cable elsewhere so u can pop it or make a hole to get the latch through. Be creative.
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Two Rings ooAUDIoo's Avatar
    May 04 2005
    2002 A4 1.8T, 99.5 2.0L GTI
    Pasadena, Maryland
    You just cut the plastic peice off of the end of the latch and bend it down. When you pop the handle from inside the car, the hood pops up high enough to slide your hand in and push the latch forward.
    2002 Audi A4:NUESPEED SPORT SPRINGS:NUESPEED EXHAUST:APR FLASH:FORGE 007:CARBONIO CF INTAKE:RIEGER FRONT LIP EXTENSION:CARACTER SIDES:PAINTED REAR AND BLADES:SMOKED TURN SIGNALS AND TAILS:H.I.D. CONVERSION:BLACK OUT UPPER AND LOWER GRILLS:18" MIGS:
    Nov 21 2008
    Bloomington, IN
    Yeah, I figured that maybe they ran the latch somewhere else, but I wasn't sure where. I'm still getting used to my shiney new A4.... well, new to me. Thanks for the help though!
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    For my mesh grill, the latch still pops out like normal. Never had to cut any holes. Only had to slightly shave the sides of the latch a bit to make it work.
    It all depends on the mesh size and pattern to get an idea on what to do.
    The one I have is the UBERHAUS hood grille found over at LLTek.com. I also put the OEM rings on it (and not the RS badge). The latch will pop out of the 2nd ring just like it does with the OEM hood grille.
    USP CLUB MEMBER #34
    Nov 21 2008
    Bloomington, IN
    I was just going to get some mesh from like, PepBoys, and attach it to the brackets of the current, stock grill. I didn't want to use the rings or anything. I'll have to see how far up the hood can go, and if I can slide my hand under it to open the latch, but I didn't think it went up that high.
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Mine is a DIY. The hole is there for the release lever, but the mesh pattern is wide enough that it isn't even noticable. Plus, I do use the rings, so that covers it up somewhat. I'm not a fan of not having the rings, but that's personal opinion.
    BTW, to threadjack, however it's nice to see someone from Bloomington. My company is based there and I'm in town a lot.
    My 2004.5 APR Stage 3+ is SOLD
    Nov 21 2008
    Bloomington, IN
    Oh yeah? What company is it? I don't mind living here, it's a nice town. I've lived here for about 9 years now.
    Veteran Member Four Rings EYE4SPEED's Avatar
    Jan 14 2008
    Macan Turbo, Cayenne Diesel, Audi Jr Quattro
    West Coast of Michigan
    Paul (CyberPMG) - do you still have the instructions to modify the hood release latch. I remember seeing something with the Uberhaus grille. Was a step by step to modify the release for mesh.
    FS: Audi TT 225Q Roadster
    Nov 21 2008
    Bloomington, IN
    I just bent the handle together some. Act like you're squeezing the "V" together. It doesn't take much, but once I pop the hood from inside the car, I can still pull up the hood a little and get at the lever inside.
    Feb 28 2006
    Pittsburgh-Philly
    Quote Originally Posted by Pestilaence View Post
    Cook Medical, Inc.
    Feb 23 2004
    Stow, OH
    Quote Originally Posted by EYE4SPEED View Post
    I think I still have it. Will try to post it up later.
    USP CLUB MEMBER #34
    Nov 21 2008
    Bloomington, IN
    Quote Originally Posted by rxrep View Post
    Cook Medical, Inc.
    Ah nice, lol... I work down the street. I'm over at Otis, doing some architectural engineering for them.
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    If you get a boser, just rock hood pins and eliminate the latch.
    -Matt
    FCDT Member #1
