Results 1 to 22 of 22
    Veteran Member Three Rings b5andm3's Avatar
    Aug 22 2008
    Central Maryland
    ebay exhaust systems and you
    http://cgi.ebay.com/ebaymotors/Testp...120103005r9278
    does that shit bolt up to an otherwise stock exhaust
    2000.5 A4Q - 2871r / 1.9L Stroked / IE Rods / JE Pistons / 3.5" TBE Exhaust / Forge MBC / 630cc Injectors / Walbro 255lph Fuel Pump / VR6 MAF / Unitronic Tune / CM FX600 / ECS N75 Race Valve / ECS 9lb Alum Flywheel / Forge TIP / Forge DV / ARP Head Studs / BBS LMs / RS4 Front Bumper / Hagus Mirrors / Brembo BBK / RS4 Shift Knob / JL Audio Speakers, Subwoofer & Amplifier / Clarion NX409 / HR Race Springs / Evolution Racewerks FMIC
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: ebay exhaust systems and you
    yes, it does. there was a thread recently about that exact one.
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Yes, and much info about this via searching.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    haha! what's the point of the o2 sensor plugs?
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Aug 22 2008
    Central Maryland
    good. i get my emissions test done today then im free for two years.
    Veteran Member Four Rings CruzS4's Avatar
    Mar 01 2007
    WK2
    Conshohocken/Sea Isle
    does the chick in your avatar bolt up to a "stock exhaust"?
    '17 Ibis White B9 A4 quattro P+ S-Line
    Aug 22 2008
    Central Maryland
    Quote Originally Posted by CruzS4 View Post
    she doesn't like audis.
    Sep 17 2006
    SLC, UT
    Quote Originally Posted by b5andm3 View Post
    then she's probably a bitch.
    Current:
    Previous:
    Aug 22 2008
    Central Maryland
    Quote Originally Posted by sean1.8t View Post
    or knows a real german car when she see's one
    just fucking with ya mang
    Veteran Member Four Rings Calabria's Avatar
    Dec 10 2006
    '00 1.8TQM
    LA
    That TP should start at 3in and tapper down to 2.5in, not start at 2.5in and go to 3in right away...
    (Ka-La-Bre-Ah)
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Anybody else think that pipe kinda looks like bent pen15? (can I say penis?)
    Veteran Member Three Rings v1nyd's Avatar
    Jun 15 2008
    Long Island NY
    many reasons, first being you don't want your o2 sensors dangling around in your bay do you? 2. there are people who tune your car that can disable your o2 sensors so you can have them in the pipe without getting a CEL. and 3 you can purchase a cel fix adapter, which its a mini tube that screws onto your tp where your o2 sensor would go then you screw your o2 sensor on the end of it and it resembles you having cat to trick your ecu which also doesn't give you a CEL with a tp. Plus for some reason you don't want to do any of the things I stated above they give you screw caps to plug it up.
    Jun 15 2008
    Long Island NY
    Quote Originally Posted by Calabria View Post
    It does start at 3inch off the turbo and coverts to a 2.5 before it ends...you must be looking at it backwards.
    Sep 17 2006
    SLC, UT
    Quote Originally Posted by v1nyd View Post
    haha, buddy. you're way out of your league...
    im not talking about the BUNGS on the TP. i know exactly what those are for and why you would retain those on this pipe. my question was, why would they put those CAPS in the bungs?
    as there is no point to capping off the bungs when the first one is needed. and the second one, if you are a 2001 or newer A4, then your software generally deletes the function of the rear o2 sensor. but you still either put the sensor in the bung or some like to put a wbo2 in that bung
    Current:
    Previous:
    Jun 15 2008
    Long Island NY
    how am I out of my league...you asked a question which I understood it one way and tried to help you by answering it, now if you were asking a different question that I knew you were and answered the same way I did then I would of not made sense but what I got from you question was why are there bungs in the tp.
    so you were asking why would they put those removable screw in caps if we're just going to take them off?...
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    probably to keep the threads clean during shipping/welding. dont want it warping or getting nicked and having to be sent back. or also pressure testing to check the welds
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Dec 10 2006
    '00 1.8TQM
    LA
    "The racing downpipe is turbo side 2.5" flange, but we designed 3" all the way after the exit!"
    (Ka-La-Bre-Ah)
    Jun 15 2008
    Long Island NY
    That's some bad designing then because my 3inch tp bolts on to the turbo then tampers down to 2.5 connecting to the flex pipe. I thought it was the same as this one
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    I really dont understand why they would even have it taper like that?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Sep 17 2006
    SLC, UT
    Quote Originally Posted by biketsai View Post
    for when you are running a sub 3" exhaust. the tapered transition between 3" and 2.5" on this tp will decrease turbulence in the exhaust system. promoting flow.
    where as with something like the ATP full 3" tp bolted to a 2.25" Borla will leave a 1.125" step all around the flange between the tp and dp. lots of turbulence created from that
    Current:
    Previous:
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Does she like innies?
    Jim
    I Do Werk.
    Aug 22 2008
    Central Maryland
    and a ko3/ko4 car does not need full 3" exhaust..
