OK. Let me try one more time to help you. Quite frankly you have been all over the map with your previous posts so it has been difficult to follow your exact symptoms. first lets address the noise. If it is ONLY occurring for the first 90 seconds or so during a cold start the noise is definitely coming somewhere from the SAI system. This only works during a cold start and will have NO effect on your overall gas mileage. The SAI pump is powered by the serpentine belt on the front of the motor. The air flow goes from the pump through a hard line on the turbo side of the motor to the Combi valve that I sent you a picture of previously. the Combi valve is opened and closed via a vacuum line (the blue line in the previous pic I posted for you). The vacuum line is controlled by the SAI air valve (N-112) located under the intake manifold. This diagram should help
Clicky click All of this is controlled by the ECU. It engages the SAI pump and allows the air flow to enter the exhaust through the combi valve on the back of the head. You already know that your pump is working. If there is any break in the lines from the SAI pump to the hard line or from the hard line to the Combi valve you will get noise. Also, if the vacuum line is broken the the combi valve will not work properly. You need to check all of that out for any problems. Usually the issue is a split hose connecting the SAI to the hard line. Or it can be the pump itself making the noise. Again, to reiterate,
none of this will cause a performance issue. Just a noisy start up.
Now to your boost questions. If you are running a stock ECU your boost will peak around 10 or 11psi and taper off to around 6 or 7psi. Perfectly normal.
As to the bad gas mileage and poor performance. what are you considering bad mileage? Can you give a better description of the performance drop? The front O2 sensor will affect your gas mileage. You mentioned that you replaced it. Did you use an OEM part or an aftermarket part? What makes you think your DV is bad? Are you hearing a "whoosh" sound when accelerating? Any additional info you can give will be helpful in determining your performance and mileage issues.
