Results 1 to 24 of 24
Thread: Wiper Refills
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Wiper Refills
    If you've ever experienced the pissed-offness of buying non-OEM replacement wiper blades only to find out that they simply don't fit our cars, here's a little tip (for the non-Aero crowd).
    The Trico 47-600 refills sold at Advanced Auto work PERFECTLY. No need to resize. Just slide out the two thin metal strips and the rubber on the OEM blade, and then slide the new refills back in.
    7 bucks. Done.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings Rommulus's Avatar
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    Re: Wiper Refills
    You're the man! Thanks!
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    Re: Wiper Refills
    nice..
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    Re: Wiper Refills
    Both sides? Any idea on the rear wiper on an Avant?
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Feb 07 2008
    just the a4
    northeast pa
    Re: Wiper Refills
    i believe this is an uber old thread... just wanted a way to get back to it easily.. i did a search in the b6 forum for "trico" and came across this... give it a shot
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    Re: Wiper Refills
    Yes, both sides.
    Sorry, can't help you with the rear.
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    Re: Wiper Refills
    Bump. This is an exact fit. Did this on Saturday. 7 bucks for both (2 in a pack)
    Thanks a bunch for the info!!
    2004 Moro Blue A4 1.8TQTip
    GIAC | Genesis | Forge | Magnaflow | RS4 | ABT | Sport | Premium | Cold | Dings mod ~ Painted lowers are overrated
    Want to see a fun coverband in the Philly area?
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    Re: Wiper Refills
    They're not aero's though are they?
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    May 03 2008
    Orlando
    Re: Wiper Refills
    no
    Kevin W.
    Oct 11 2008
    2002 Audi A4 1.8T Tip
    Connecticut
    Re: Wiper Refills
    I have a B6 and just bought the 47-700s. If I dont return them, what will I need to do to install them. Do i need to cut them??? Should I just go return them and get the 600s and if so, how do you install them. Do you need to undo the clips at the top of the wiper blade??
    Senior Member Three Rings Certified MD's Avatar
    Dec 06 2008
    88 Mustang 5.0 LX Hatchback
    Orlando
    Re: Wiper Refills
    Good tip brotha - I'm taking this advice.
    Veteran Member Four Rings kelseysautobody's Avatar
    Mar 03 2009
    Cape Cod, MA
    Re: Wiper Refills
    Good call ... but after two to three insert replacements the wiper body loses its spring and doesn't put enough pressure to work effectively. Its still more cost effective than getting oem wipers every time tho
    2013 S4 S-tronic - 3.47 PR // EPL DP ECU/TCU tune // PLM hx // APR intake // Jokerz Blower // Headers // Ice box // iABED TB // Autotech HPFP // RS7 LPFP
    11.186 @ 123.35
    1993 URS4 - GT3071R - EFI Express Tuned - Gutted
    Past: 07 S4 6MT ~ 03 A4 3.0 6MT ~ 99 A4 1.8T
    Veteran Member Four Rings A4OrlandoB6's Avatar
    Aug 03 2008
    Philadelphia, PA
    Re: Wiper Refills
    i bought rain-x arms when i got the car because they were "awesome" and "cool" and i pissed myself off so bad trying to get them on. and i somehow broke my stock arms. but i found yet another use for some zip ties.
    -Kyle
    2005 Audi A4 Avant USP / 1.8T / Brilliant Red
    2004 Audi A4 1.8T - big turbo and some stuff - gone
    2003 Audi A4 1.8TQM - gone
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    Just completed my $7 wiper refill investment. So far so good! Sure beats the stealership prices!
    Oct 06 2010
    1989 Nissan 240sx S13 Hatch 2015 Nissan Versa 2005 Toyota Sienna
    Virginia Beach
    I wish I known about then this before I went out and got some random blades and ending up returning them b/c they didn't fit. Also does anyone know a link for the DIY for the replacement. I can't them off my wiper arm.
    Apr 01 2005
    one wagon one truck
    Michigan
    Wow, can't wait to try this. Ill pick some up when I take my video back to the red box.
    Veteran Member Four Rings jcg05c's Avatar
    Jun 07 2007
    350z
    orlando
    and Kevin a thread of your arises again haha
    19in Privat Netz 10mm front/17.5mm rear
    Apr 1+
    TurboSmart Bov/Dv
    Roof Spoiler
    Jeff Lee Test Pipe
    NS Boost Gauge
    Senior Member Three Rings 03 silverbullet's Avatar
    Dec 05 2008
    1.8 Q 05 GSXR 03 CBR RR
    i have used these before and now i have those awesome wiper scratch marks all over the windshield. So i took that refill pair off and replaced them but it did not matter it was too late. Anyone know how to repair the scratches ?
    May 03 2008
    Orlando
    You must not have installed them correctly.
    Kevin W.
    Dec 05 2008
    :-) i hope i have enough mechanical skill to install them. I did change my timing belt and water pump. I am not sure how they can be installed wrong.
    you know how to remove the scratch marks that the blades have left behind ? glass polishing kit or restoration ?
    Jun 06 2005
    Montana
    Thanks for the tip. I just did this. Seem to work fine, we'll see tomorrow how they hold up in a snowstorm. It took me a minute to figure out how to get the old blade off. They slide in through the clips but the one in back is clamped down to keep the entire thing on. You have to pry that open to slide the blade out and then clamp it back down with pliers or something to hold the new one in place. I don't think I saw that info in this thread, and it may not be so intuitive to some (like me). Probably will go aero though after this.
    Nov 19 2010
    Maui
    Quote Originally Posted by 03 silverbullet View Post
    Harbor Freight had a glass polish kit in a box with foam pads you used with your drill and with what I am guessing is diamond powder on the pads. It worked well on a windshield I did. Years ago I used some flouro acid something or other but be very careful and not get that on your skin, I know very little but it is bad to soak through your skin.
    So the goodyear wipers that costco sells won't fit on these cars? Bummer, I love those.
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    Wiper Refills
    Used this again! The rest of the wiper is for sure getting weak (this is the 4th time I replaced just the blade), so I think the aero upgrade is in the near future.
    Daniel J
    @gtg_drives
    May 03 2008
    Orlando
    I finally switched to the Aero style last year. It took a couple of months for them to stop skipping across the windshield. It drove me NUTS. There were suggestions to claybar the windshield, swap the driver and passenger side arms, etc., but it just took time for the skipping to go away. They were almost unusable at first.
    Kevin W.
