Page 1 of 4 123 ... LastLast
Results 1 to 40 of 141
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    128 days later…….
    …….And my car is finally back on the road! The piston rings seized two days before Waterfest when I was getting my car checked out before the drive to NJ. I took it out to drive for the first time yesterday and started breaking in the engine. So far it’s running great and it’s just begging for more boost.
    The bottom end was rebuilt with new pistons, bearings, main bolts, and the oil pump. I was able to re-use the block after having it honed. D + D Racing Engines rebuilt the engine and checked the head for any damage. They balanced the entire rotating assembly including the clutch and flywheel.
    I decided to put all of the downtime to good use and add a few upgrades. DTR Performance built a custom intake manifold to go with an R32 throttle body along with a set of Cat 3658 cams. I bought a Snow Performance water/meth kit to install along with a Bosch 040 fuel pump that will be installed as soon I’m ready to turn the boost up.
    With all of the problems that people have been having with Southbend clutches lately I thought it would be a good time to upgrade my clutch. I picked up a Clutchmasters FX 600 twin plate clutch with a 14lb steel flywheel from Greg@DTH. So far it’s a lot different than the Southbend FE SS. What I’ve noticed so far is that it has a very light pedal feel and engages very quickly. It was a little tricky at first but I think I’m getting the hang of it. I’ve only put about 125 miles on it so I’ll wait to post a full review until it’s broken in.
    Original build thread
    Engine failure thead
    Here are a few pics of my setup as it is right now. I’ll try to get some vids as sometime this week.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: 128 days later…….
    Great to hear John!
    How is the clutch feeling?
    How do the logs look? Compression looks good?
    -Doug
    Feb 17 2005
    Sarasota, FL
    Nice! Glad shes back in one piece and running again! Might want to try losing that TIP and running open turbo!
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Great to hear John!
    Clutch is getting better. It was rough at first but I'm getting used to the engagement point now. Everything is looking good. Just have to keep driving it every chance I get.
    Quote Originally Posted by A4ringedONE8T View Post
    I might mess with different setups when the engine is broken in. First I need to figure out why it is randomly stalling when I'm getting ready to stop.
    Saint Cloud, Fl
    Does the clutch chatter ?
    instagram ------------> low_enforcement
    Feb 17 2005
    Sarasota, FL
    DV/BOV sticking open? Do you have any pics of the manifold off the car?
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    dont think i've seen you before... but great looking ride, man..... im jelous.. very.. in a nice way ...
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Quote Originally Posted by 7speed View Post
    It does a little but not as much as everyone thought it would. You can't hear it with the radio on and it goes away if you hold the clutch in.
    Oct 29 2005
    10speed
    San Francisco, CA
    John, 128 days is nothing lol...
    Glad to see it back out, should be a beast... Now all u need is a tune
    - Clint
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    It's a Tial BOV and I was told that it might need some grease. Here are a few pics of the manifold while it was being made.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Quote Originally Posted by Condo View Post
    It's the cams, the ECU will compensate eventually. You'll notice some hard hot starts also. Just give it a little gas and it'll start.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Quote Originally Posted by EUROaleksey View Post
    It seemed like forever. It was supposed to be done in two weeks for the last two months. Kept hitting delays. How soon will your car be ready?
    It's running really strong right now. Can't wait to turn up the boost. I'm looking at a few different options for a tune and should have it figured out early next year.
    Saint Cloud, Fl
    Would it be possible to get a video of how the clutch sounds ?
    Buncha motorcycles
    Memphis, TN
    he said yes, but its barely noticeable. you cant hear it with the radio on
    APR Stage 2/AWE Intake
    Mar 21 2006
    Lakeland, FL.
    That's not a good descripsion, I can't hear mine with the radio on either, but it chatters like a bitch.
    I'm back bitches!
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Quote Originally Posted by dirtybrd View Post
    It was doing the same thing with the last build on stock cams. Thanks for the tip on hot starts. Luckily I haven't had any problems so far.
    I'll try to get a video of it this week. The exhaust is louder than the chatter at idle both inside and outside the car.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    OEM cam gear right?
    stalls when the car is cold or both cold and hot?
    Like Chris said, the ECU has to adapt. Should get better but only time will tell.
    I know why mine kept stalling out. That is all fixed now with the custom tune and OEM cam gear. The REVO file can't compensate enough for it. That's why Chris has hot start problems too. There's a few maps that need to be tweaked. We just did all that on my car.
    -Doug
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Love the setup.....3076, right?
    In the second pic of the Intake manifold pics...what is it that we are looking at? (What is it that was added to the runners?)
    -Sami-
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    OEM cam gear right?
    Yeah, OEM cam gear. Idle is usually good as well but has a few hiccups every once in a while.
    Why was your car stalling?
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Correct.... 3076
    The stock plenum was cut off and a 1/4" sheet of aluminum was welded in. The stock ports were blended with the ports in the aluminum sheet to give them more depth.
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    dear lord those are some huge parts in your engine. looking really good man, congrats to being back on the road!
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    May 24 2007
    Southern California
    sweet deal.
    most of my gear is at the machine shop as well. bored, honed, balanced (clutch/flywheel)
    waiting for the aeb head (thanks doug) to arrive and off to the shop she goes as well.
    im gonna try the fx300. thats all i need.
    Kyle
    2.0L Revo GTRS Eliminator
    Aug 26 2005
    Open turbo? As in driving without a functional air filter installed? You must be joking, right?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I had the adjustable cam gear in and it was advanced providing timing advance at idle which the ECU didn't like. Car would stall when cold and it idled 'ok' once warm but still not perfect. One reason why we went back to an OEM cam gear and are taking up the timing advance via the ECU.
    -Doug
    Feb 19 2007
    Charleston, SC
    sure he means with some chicken wire strapped in place....
    -Sami-
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    My car has never stalled once and I have cams while running the revo software.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    He means no TIP but an open element.
    I'm back bitches!
    Mar 21 2006
    Lakeland, FL.
    Quote Originally Posted by A4 TSCHUSS View Post
    You have girl cams.
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    your mother has girl cams! Mine are 252/260 that isnt that much different
    ~David~
    CTS-V 9.6@148
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Quote Originally Posted by LampyB View Post
    Thanks! Feels great to have my car back.
    Quote Originally Posted by A4natomical View Post
    sweet deal.
    Sounds good. The AEB head should make a big difference. How soon do you think you'll have everything together?
    I'm pretty sure mine has something to do with the Tial BOV.
    Mar 21 2006
    Lakeland, FL.
    Are you running a MAF? Disconnect the signal line to the BOV and see if it stops stalling.
    I'm back bitches!
    Jun 30 2007
    Raleigh, NC
    Try doing a TBA to see if it helps the stalling and idle - also check my thread about my problems and see if any of that helps.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Oct 29 2005
    10speed
    San Francisco, CA
    God knows how long... I have a little trick up my sleeve and im the prototype for a new part coming for us bB6ers... nothing special but helpful for the BAT crowd ... its just $$ holding me back at this point but im working on it
    - Clint
    Mar 21 2006
    Lakeland, FL.
    BTW, Revo is coming out with an updated 550 file and something for us BAT guys.
    I'm back bitches!
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Still running the MAF. I was thinking that it may run better without it.
    Quote Originally Posted by B6Lovin View Post
    That's another problem. I can't do a TBA in Vagcom. I get an error every time. It reads the throttle angles correct though.
    Mar 21 2006
    Lakeland, FL.
    Is you have a BOV issue, like it opening at idle, and a MAF it'll stall.
    I'm back bitches!
    Veteran Member Three Rings Carlitos's Avatar
    Sep 17 2006
    B6 A4 1.8T
    San Juan, PR
    when is this update be out? I haven't flashed my ECU w/REVO yet... might wait for this...
    sry for threadjack///
    back2topic -->
    FlexTuning
    Amulet 1.8TM
    BAT#46
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Great news John! Glad you have your car back. When I saw the thread title I was scared a little.... was under the impression your car was infected or ill
    Looking foward the see your impressions when you start pushing the car more.
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    May 24 2007
    Southern California
    good to know. hopefully by the time my setup is nearing its completion it'll be out!
    Kyle
    Dec 03 2005
    2 pedals 1FG
    connecticut
    good luck getting that one. you'll be waiting for quite a while..
    -Doug
