Results 1 to 7 of 7
    Veteran Member Four Rings the_pirate's Avatar
    Apr 08 2008
    Houston
    B5 AWM Engine Code Thermostat Removal Write-Up
    I did this write up over on fourtitude. I figured someone on here might need it too.
    http://forums.fourtitude.com/zerothread?id=4132965
    History:
    2001 A4 1.8t manual swapped
    2007 GMC Sierra ext cab
    2002 Chevy Tahoe Z71
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: B5 AWM Engine Code Thermostat Removal Write-Up
    Thanks for the write up!
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    nice write up!!
    Veteran Member Three Rings hernandez3011's Avatar
    Mar 21 2008
    United States
    awesome, I was planning on replacing the thermostat this weekend. Thanks man
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    will the thermostat fix this problem? Currently, my outside temp guage would go into the negatives when it's obviously in the mid 50s here in San Francisco, CA. When the guage does go into the negatives, the ventilation system blows nothing but hot air! :[
    thanks!
    TEAM|AXION
    Registered Member Three Rings kovalevandrew's Avatar
    Oct 19 2008
    South Africa
    I hate it when everything on my engine is different to anything i find online.
    Good writeup though.
    Apr 08 2008
    Houston
    Quote Originally Posted by speedydragon View Post
    thanks!
    that would be one of your thermometers (i dont know what they are really called. someone can chime in) i think there is two in the engine bay and they control what temperature your a/c blows. like if its -5 outside i dont think your a/c will blow ice cold air.
    one of mine is going bad because i have the same problem in the summer when it gets super hot. the temp. gauge on the dash computer starts going crazy. it is different then your engine temp. gauge.
    History:
