Results 1 to 11 of 11
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    What spacers to use with stock wheels?
    I'm using my stock wheels on my Avant and would like to push them out so that they're flush with the fender lips. Anyone running the stock wheels with spacers? I'd appreciate any info available.
    I don't see why the A4 would be different than the S4 as far as hubs goes. I think that they're common parts between the two cars. Correct me if I'm wrong.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Registered Member Three Rings Buegie's Avatar
    Sep 18 2007
    e90
    Re: What spacers to use with stock wheels?
    Dont mean for this to sound rude at all, but I dont see why people ask this question. Just take a ruler and measure the distance from the wheels to the fender lip. Convert that to mm and thats the spacer you need. I can tell you what it should take, but there's no reason for guessing when the wheels are already mounted
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    I don't see what's the harm asking a question that someone can answer from personal experience...
    Senior Member Three Rings simona's Avatar
    Jun 18 2007
    B7
    silicon valley
    Depends on if your spacer have anything sticking out, my ECS spacer centercircular lip is too large for my stock S4 wheels.
    In, Out and Around...
    Quote Originally Posted by AudiOso View Post
    10mm
    Veteran Member Three Rings J.the W.'s Avatar
    Aug 30 2007
    2014 CP M5, 2006 Pathfinder LE
    Az.
    I've got 8mm front and 10mm back.
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Thanks guys... I appreciate the information!
    Veteran Member Three Rings poopypants's Avatar
    Jun 18 2007
    '64 LeMans, '00 CBR929RR
    Perris, CA
    15 mm on the back.
    "The Constitution of most of our states (and of the United States) assert that all power is inherent in the people; that they may exercise it by themselves; that it is their right and duty to be at all times armed."
    - Thomas Jefferson
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    Quote Originally Posted by iconoclast View Post
    10mm
    2nd, that is what I am running, they are the H&R track spacers
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    15mm rear and 10mm front should do it. But measure for yourself first!
    Aug 30 2007
    Az.
    Make sure you get hubcentric spacers.
