Originally Posted by
05Audi1.8T
k so say i buy some ecodes from parts4euro. do i have the buy the bulbs also? and u say i should buy the 4500 ones. i know i usually use the h7 right now. not sure if those work with ecodes?
The problem with the aftermarket e-codes, is that they have H7 halogen projectors, even if HID D2S lamps are used, the optics of the H7 projectors are not designed to be used with HID light sources. The result is that there will be uncontrolled glare for oncoming drivers, creating a hazardous situation. Installing HID light source in a H7 Halogen projector is not legal, all the retrofit kits are not legal either.
The correct way to upgrade your headlights to HID/xenon, is to obtain OEM Valeo headlights, you can get the black interiors with e-codes, and you will need to get a OEM HID kit that provides the ballast, D1S HID lamp, and the cable to connect the ballast to the D1S lamp igniter. The lamps with 4300K color temp, have the most light output at about 3200 lumen. Higher color temps will have lower lumen output, but 5000K to 6000K are white to blue white, without loosing to much light output, and provide 2400 to 2800 lumen. Be careful to buy only genuine Philips or Osram D1S lamps. ( I know of only one non OEM hid burners source, that are good quality, but most are crap.)
