Results 1 to 4 of 4
    Veteran Member Three Rings PhunkFX's Avatar
    Oct 11 2005
    2019 TTRS, 1989 VW Cabriolet, 1986 VW GLI, 2015 Cayenne Diesel
    Post Falls, ID
    Keep getting these DTCs when I turn the headlights on. Please help?
    What the hell is going on here? Blinking ABS Brake light, and ESP light is on too!
    Sunday,23,November,2008,15:15:48:59297
    VCDS Version: Release 805.1
    Address 01: Engine
    Control Module Part Number: 8E0 909 518 AK
    Component and/or Version: 1.8L R4/5VT G01 0003
    Software Coding: 0016711
    Work Shop Code: WSC 63351
    1 Fault Found:
    18057 - Powertrain Data Bus: Missing Message from ABS Controller
    P1649 - 008 - Implausible Signal - Intermittent
    Readiness: 0000 0000
    Sunday,23,November,2008,15:16:48:59297
    Address 03: ABS Brakes
    Control Module Part Number: 8E0 614 517 A
    Component and/or Version: ABS/ESP allrad 3429
    Software Coding: 04275
    Work Shop Code: WSC 06435
    2 Faults Found:
    18256 - Please check DTC Memory of Engine Controller
    P1848 - 35-10 - - - Intermittent
    65535 - Internal Control Module Memory Error
    00-00 - -
    Sunday,23,November,2008,15:25:42:59297
    Address 01: Engine
    1 Fault Found:
    Readiness: 0110 1101
    -Ricky
    2019 Audi TTRS Prestige | Stage 3
    2015 Porsche Cayenne Diesel | Stage 2
    2015 VW Golf SEL TDI 6MT | Stage 2
    1986 VW Jetta GLI Wolfsburg Pirelli w/11k Orginal Miles
    1989 VW Cabriolet | 1.8T K04 w/nitrous
    Oct 11 2005
    Post Falls, ID
    Re: Keep getting these DTCs when I turn the headlights on. Please help?
    My keyfob isn't working not either.
    -Ricky
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    bump. Ijust got the same DTC when I turned the headlights on.
    My drivers side bulb has been blicking on and off for about a month now, and tonight the bulb flickers ever so dimly for about 2 second and then just stays off. When that happened, the ABS light and traction control light came on as well as a flashing "brake" light.
    What is going on?
    I also, tried to access the ABS brakes module via vagcom and it says there is no response from controller. Its like vagcom cant connect to the ABS module.
    Any ideas?
    -Sami-
    Oct 11 2005
    Post Falls, ID
    What type of headlight setup do you have? I have an aftermarket HID kit, and what happened to me was combination of bad bulbs and a bad ballast. The bulb was all twisted and such... but the ballast was causing a HUGE voltage spike.
    With the bulb out and the connector in sight, i turned the light switch on and saw sparks shoot out of it. The voltage spike was throwing off the ABS and such... which is BAD! I had a spare ballast and I threw that in... no huge spark.... I also put in a spare bulb... put it all back together... and from then on, I have had no problems with this again.
    The cause: cheap/bad aftermarket HID parts.
    The solution: replace the bad parts with new.
    -Ricky
