Results 1 to 9 of 9
Thread: Please Help
    Jun 25 2008
    98 a8
    phoenixville
    Please Help
    My heat stopped working and its getting cold. If anyone has any ideas on what i can check let me know.
    Thank You
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Re: Please Help
    you could just need to flush you coolant...or it could be a number of things such as T-stat,air bubble in your system, heater core etc...Just hope it is not the heatercore.
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Jun 25 2008
    98 a8
    phoenixville
    Re: Please Help
    How do i know if its my heater core?
    May 31 2008
    New York
    Re: Please Help
    there is really no sure way to tell..When is the last time you changed your coolant? Should be pink assuming you used g12 coolant. How is your water tem gauge in your car? does it stay dead center?
    Jun 25 2008
    98 a8
    phoenixville
    Re: Please Help
    the coolant is pink in color the temp gauge sits below the middle line and stays there.... my car never overheats..... i have a bad feeling its the heater core..... what does one cost and how hard is it to install?????
    May 31 2008
    New York
    Re: Please Help
    Not sure about the cost possibly around three or four hundred. The labor is going to be the expensive thing bc the heater core sits in your dashboard. The whole thing has to come out.
    Jun 25 2008
    98 a8
    phoenixville
    Re: Please Help
    WTF!!!!!!!!!! Can you get to the heater core by removing the blower motor and its box?? I just replaced the blower motor and i remember seeing it under the box where the motor sits.
    May 31 2008
    New York
    Re: Please Help
    I'm not exactly sure where it sits in your car. I kno on b5 s4's it is located inside the dash.
    Registered User Four Rings OEMplus.com's Avatar
    Feb 27 2004
    2x VW, 2x Audi
    OC, CA
    Re: Please Help
    Pretty sure it's inside the dash... dealership could tell you...
