Results 1 to 9 of 9
    Registered Member Two Rings john doe's Avatar
    Mar 07 2008
    2001.5 s4 Pearl White
    pa
    power steering hose replacement ( how ) help
    i belive i blew a power steering presser line hose , any help on fixing it , like whats involved help , please
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: power steering hose replacement ( how ) help
    Quote Originally Posted by john doe View Post
    What makes you think the hose blew?
    08 S4- Stock SOLD
    Mar 07 2008
    pa
    when when i turned the wheel all the fluid can out , not in the front of the eng but it was leeking in the rear behind the eng , i dont know for sure what it is yet , but my guess is the hose . i cant see any of the hoses or anything very tight in there . any idea on what to look for or what u think it is ?
    Jan 29 2007
    08 S4 00 S4
    MD
    Sounds like it could be a hose or the rack. I was just curious how you came to the conclusion. I don't hear much about blown hoses usually.
    08 S4- Stock SOLD
    Mar 07 2008
    pa
    well its a guess . im hoping just a hose . i dont see any fluid on any of the boots , thats what makes me thing its a hose .
    is it a ez job replacing a hose , or a nightmare
    Jan 29 2007
    08 S4 00 S4
    MD
    Never had the pleasure..Doesn't sound like fun if you can't even see where it is though
    08 S4- Stock SOLD
    Mar 07 2008
    pa
    did anyone ever mess with it ???
    Nov 25 2008
    Roc
    The high pressure line hoses are expensive, about $300 each. They are both hard lines with large rubber hoses crimped in the middle. Banjo fittings on one end, threaded on the other, the lower hose has distinctive coils at the banjo end.
    The upper hose goes from the pump (front and center, top pulley) to the lower hose. From the pump, the hose routes towards the back of the engine underneath the y-pipe. It emerges on the passenger side, you should be able to see it if you remove the accordion elbow on the intake. From there it screws into the lower hose. The lower hose routes underneath the ledge that the battery sits on to the rack. If you remove the driverside fender liner, you should be able to see the rack and lower hose.
    2000 s4
    Fairfield, CT
    there is a hose that runs along the right side valve cover that tend to leak i have replacedthat before. check the p/s "cooler" aka the small peice of bent metal tubing in the front. the clamps there also leak. and a rack or a pump isnt uncommon either
    i heart my s4
