Results 1 to 6 of 6
Thread: Oil Light
    Sep 13 2008
    Western Chicago Burbs
    Oil Light
    I have a 2002 a4 3.0 and when i am running my car hard, my gauge console screen shows the big oil symbol which i think means that the oil is low. if i go check my oil right when this happens, the oil level is fine. i'm using penzoil platinum 5-40(bought the car used and thats what they put in it) could this be a bad sensor? sludge?
    Sep 04 2008
    p
    Re: Oil Light
    Is the oil pump that has no pressure, stop the car or you will blow your engine.
    Senior Member Two Rings Shi-Fu JaY's Avatar
    Apr 06 2008
    Fontana, SoCal
    Re: Oil Light
    had that happen to me once! but I was in the process of doing the seafoam treatment, so im guessing seafoam had something to do with it.
    It has not happend since.
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Re: Oil Light
    Just put a piece of black tape over the idiot light on the gauge and drive it like you stole it....
    or not...
    My 2004.5 APR Stage 3+ is SOLD
    Registered Member Two Rings
    Nov 03 2008
    Layton, UT
    Re: Oil Light
    Check your oil pressure with a gauge if you have one. I took mine to the dealership and they checked the pressure and diagnosed it for $50. Pressure was perfect and it ended up being the oil pressure sensor and cost me $18 to fix myself.
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Re: Oil Light
    Sludge is the big issue on the 1.8. Since you're 3.0 I wouldn't panic like I would on my car but perhaps consider doing the amsoil or seafoam treatment and getting the oil and filter changed (I support synthetic regardless of 1.8 or 3.0). It's true the pump could be impeded at the pickup but who knows. 1_ate_t shows it could be a sensor so that's not out of the question.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
