Well the past few months i've been having nothing but shifter issues. As of 2 days ago basically the shifter is so sloppy that it wont go into 2nd, 4th 6th. And before we say alignment issue , well i've been there before, many hours.
Basically when youre in the upper banks(1,3,5) of gears when you try to take it out of gear the shifter moves back about 2-3 inches before going out of gear into neutral, by that time the shifter is already at the position of the lower bank of gears (2,4,6_ the up down movement seems to be tracked down the shifter linkeage by the tranny. The balljoint is stock and seems its SUPER sloppy in there, to the point to where i can move the linkeage rod back and forth fron underneath and the ball joint just moves along rather than actually shifting. I had my buddy look how much the shifter inside the car moves while i move the rod from underneath and basically 2-3 inches before going into gear.
Also a upate: I had my buddy basically keep it in neutral but move the shifter up and down. The part that bolts onto the transmission moves with the balljoint as it should. but it seems either whatevers inside the transmission, or whatever it connects to, lets the entire thing move around a lot before even thinking of hitting a gear...So the balljoint isnt so much the problem but whatever it connects to, transmission wise.. this sounds serious.
