    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Help - Hood stuck OPEN
    I've seen lots of threads about hoods being stuck closed, but mine is stuck OPEN. When I drop it to close it, it bounces back up. It seems like the latch went to the closed position or something thinking that the hood was down.
    Any ideas how to fix this? I don't want to try slamming it any harder because I know what's happening isn't normal. The U-shaped latch on the actual hood is slamming into two silver bars on the latch mechanism on the frame of the car. It's like those two silver bars are locked in place and not allowing the U-shaped part from the hood to engage.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    May 03 2008
    Orlando
    Re: Help - Hood stuck OPEN
    UPDATE:
    Ok, I got it to close, but I had to manually push the release lever back to its starting position in the driver's footwell. When I pushed the release lever back to its starting point I could drop the hood and it would latch.
    For some reason I have to do that every time I want to close the hood now. If I just pull the release lever, pull the lever in the grill, and then open the hood, I can't just drop it back down to latch it. I have to go back into the car, push the release lever back, and then go drop the hood.
    Anyone seen that before?
    Kevin W.
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 2.1t, 2015 Q5 3.0t
    MOntreal
    put some oil in the latch be careful with that shit cuz if you break the cable it will be a bitch to open it after..the cable has a ball at the end, you can unclip the cable from the latch and drop some oil in it
    BetaAlphaTau member #19
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    I had the same problem. Tried some silicone spray to no avail. Had to replace the whole latch system. Wasn't too pricey though, which I was surprised about.
    May 03 2008
    Orlando
    After driving around a little bit, it seems to have fixed itself - I don't have to push the inside release lever back to the starting position. Whew!
    Kevin W.
