Results 1 to 21 of 21
Thread: VAG-COM wanted
    Veteran Member Four Rings Yevmeister's Avatar
    Mar 08 2008
    i haz a boat
    Wilmette/DeKalb
    VAG-COM wanted
    anyone with VAG-COM, my car is acting terrible
    Yev
    Apr 18 2008
    Jacksonville, FL
    Re: VAG-COM wanted
    bit of a drive (menomonee falls), but i've got it.
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Senior Member Three Rings eurotecknik's Avatar
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Re: VAG-COM wanted
    I've got a Vag-com. I live in Norridge. Maybe you can help me too, I need some help with removing and installing a cup kit on the rear only. Do you have experience with suspension
    01 A4 1.8T Quattro Manual - SOLD
    90 Audi 90 Quattro Manual - SOLD
    03 A4 1.8T Quattro Manual - SOLD
    B5 S4 Daily Driver - SOLD
    Current:
    06 A4 Quattro Auto
    Mar 08 2008
    i haz a boat
    Wilmette/DeKalb
    Re: VAG-COM wanted
    i could lend you an extra set of hands, however i don't have the experience on working on suspension
    I am looking for something to do on thanksgiving day anyway
    Yev
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Re: VAG-COM wanted
    I will see if I am up for the challenge to work on it. I will probably end up giving it to someone. Anyway if you want to use my Vag-com, we can just meet up. I will be happy to help you.
    Current:
    06 A4 Quattro Auto
    Account Terminated Four Rings
    Feb 18 2008
    A4 Avant 1.8TQM
    Downers Grove
    Re: VAG-COM wanted
    Quote Originally Posted by Yevmeister View Post
    Yev
    whats it doing? and did u check ur coolant levels after the tbelt job?
    Mar 08 2008
    i haz a boat
    Wilmette/DeKalb
    Re: VAG-COM wanted
    coolant is perfect
    i went to autozone
    1) low fuel levels (seems like injectors)
    2) Cyl 2 misfire
    3) Open circuit somewhere
    i need Vag-Com for more accurate
    i also think that maybe i rear differential acting up
    Yev
    Feb 18 2008
    A4 Avant 1.8TQM
    Downers Grove
    Re: VAG-COM wanted
    coolant is perfect
    i went to autozone
    2) Cyl 2 misfire
    Yev
    Cyl 2 was where u had that loose coil pack, get new plugs.
    low fuel levels is a bad fuel filter, change that
    open circut is most likey your A/C condsenor being unplugged.
    just my two cents....
    Feb 18 2008
    A4 Avant 1.8TQM
    Downers Grove
    Re: VAG-COM wanted
    Quote Originally Posted by eurotecknik View Post
    if you need a hand let me know....I've did full suspension rebuilds in both of my old A4's, i could advise a bit.
    Mar 08 2008
    i haz a boat
    Wilmette/DeKalb
    Re: VAG-COM wanted
    x2 i could join, we could have a build up party
    lol
    preferably on thursday, sunday will work too
    Yev
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: VAG-COM wanted
    +1 on Vagcom.. i'm getting new plugs tomorrow and need to see whats going on
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Senior Member Three Rings PMR2.7t's Avatar
    Mar 26 2008
    2003 A6 2.7T
    Harwood Heights, IL
    Re: VAG-COM wanted
    I have a vag-com i can help if you want ....
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: VAG-COM wanted
    ^^^Cool, let me change the plugs in a couple of days and i will send u a pm :) thank you.
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Re: VAG-COM wanted
    Quote Originally Posted by Koselowiec View Post
    Ok, I just have to do wheel bearing now. Drivers side rear. I know it is fairly easy but never done it before. If you can help me a little that would be great. Also, I dont know any shops that could separate the bearing from the hub and press the new on in. I costs about $30 as far as I know
    Current:
    06 A4 Quattro Auto
    Feb 18 2008
    A4 Avant 1.8TQM
    Downers Grove
    Re: VAG-COM wanted
    well you can get it pressed at almost any shop....
    what ive done because I won't drop $300 for the tool, its take out the hub carrier, beat the old bearing out of the hub, and then just use a vice to press the new one in using the old bearing. its ghetto, but it worked well for me and saved me a lotta money.....i might have a new bearing lying around too.
    Feb 18 2008
    A4 Avant 1.8TQM
    Downers Grove
    Re: VAG-COM wanted
    .....ok. i am asking for a VAG-COM for christmas.
    Senior Member Two Rings joeS407's Avatar
    Dec 20 2007
    2000(B5) S4 Hibiscus red
    naperville
    Re: VAG-COM wanted
    hahahah you should have got one when you got your first a4
    Veteran Member Four Rings jursch2211's Avatar
    Feb 05 2008
    Illinois
    Re: VAG-COM wanted
    i have one if you need to use it and since i'll be putting my car up for sale, my vag-com is up for sale too. PM if interested.
    || APR | BW K04-015 | ER FMIC | OEM S4/RS4/R8 Parts | '10 RNS-E | Hotchkis | Adam's Rotors | Podi | OCarbon | Euro Headlights | Euro Color DIS | Euro MKII TT MFSW | Euro Trunk | BBS | Vogtland Coilovers ||
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: VAG-COM wanted
    alright, so who can help me out with their Vagcom tomorrow?
    Feb 05 2008
    Illinois
    Re: VAG-COM wanted
    This is belated but where are you located and I could possibly help ya?
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: VAG-COM wanted
    ^^^ Thank you, i already Vag'ed it, but still havent fixed it :)
