Results 1 to 2 of 2
Thread: HTC Touch Pro
    Active Member Two Rings sjporzio's Avatar
    Apr 08 2004
    2006 25Quattro
    Connecticut
    HTC Touch Pro
    Able to get touch pro connected to bluetooth in 2006 25quattro, but cannot access my phonebook. Not even sure how to do it even if compatible... any assistance is appreciated
    Senior Member Three Rings blackbox619's Avatar
    Oct 24 2008
    nyc
    Re: HTC Touch Pro
    make sure your bluetooth is on and visible to other devices. in settings, hit the 3rd tab on the bottom where it says "connections". inside the connections tab, touch the bluetooth symbol. once inside that folder, look at the 4th tab for "sim access". make sure that the sim access box is not checked off. now go to the last tab "security". make sure that the "authentication" box is not checked off. that should be it and you're good to go. if these tips dont work then i believe that the audi bluetooth is not compatible. good luck.
    ~~ engineered in germany... modified in brooklyn ~~
