Results 1 to 39 of 39
    Registered Member Two Rings
    Nov 03 2008
    Layton, UT
    tiptronic transmission questions
    My tiptronic seems to slip around 3800 RPM's for a second before it grabs again and starts pulling again. Is there something to do to try to fix this so it will pull through out the RPM's? TIA!
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    Re: tiptronic transmission questions
    Mine does the same thing, but only in 2nd and 3rd. Get going at about 2000 rpm in first and bury the throttle, see if it does it then.
    The problem is a combination of a hole in the stock ECU map and the adaptive throttle profile.
    Nothing you can do while it's stock.
    Aug 26 2005
    What you are feeling, is the torque converter clutch locking up after the shift to second gear. The bump can feel like an extra gear shift. Change the ATF every 30K miles to help maintain firm shifts with minimum clutch slip, old fluid will provoke glazing the clutch friction faces, causing increased slip and heat. Pentosin ATF-1 fluid is recommended.
    Mar 20 2006
    I don't think it's the TC because it happens well below WOT. It's just a slight pause at about 3800 RPM.
    Also, if it was the TC, wouldn't it happen in first as well?
    Dec 06 2007
    ^^Kurt ur making a huge mistake ur arguing with the master! He's right it is the TC the mapping of the ECU has nothing to do with this, it is just the stall rate of the TC and if it is at 3800RPM's like u say it may also be the small turbo lag where full boost kicks in and for a second there it hesitates.
    -Kirk
    BetaAlphaTau Member #58
    Mar 20 2006
    Oh, I'm definitely not arguing with the big D.
    Veteran Member Three Rings Rons01B5's Avatar
    Oct 17 2005
    Long Island, NY
    If you are in drive (D) the TC loves to slip a little, even at 3/4 throttle. Drive in tiptronic mode, locks TC in second gear.
    2012 A5 2.0T QUATTRO 6-SPEED
    GIAC Stage 1---R8 Coilpacks---H&R Coilovers---S5 Speedline Wheels---H&R 20mm Spacers---Ecode Alu Kruez---H&R Sway Bars---034 Trans Insert---P3 Cars Gauge---JHM Shifter---GFB DV+--S-Line Front Bumper---Black Optics Grille
    2003 Amulet Red Audi A4 1.8TQ 5-Speed - SOLD
    Nov 03 2008
    Layton, UT
    Thanks for the tips guys. I'll take it for a spin here in a little bit and see if it does it in tiptronic mode. If it doesn't, is my best bet to try changing out the fluid so i can drive it in full auto mode without the hesitation? Any would a aftermarket chip help at all? Thanks!
    Nov 03 2008
    Layton, UT
    So I took it for a spin again, in regular drive and sport, it slips around 3800 rpms. In tiptronic mode its perfect. Is there a way to make it not slip in regular drive or sport mode? Would a chip help or a tip chip? Thanks!
    Feb 13 2004
    04 audi a4 1.8t ultraspor
    woodlands
    Quote Originally Posted by 1_ate_t View Post
    For me in D it hesitates around 3800 but when I'm in tiptronic it will hesitate at something like 2800 or so... shift to second at 15-20 mph and just slowly accelerate and it'll happen. Why does it change where it slips when you are in D vs. tip? This has been happening since I got the car. I never noticed it on the test drive but later on figured out it was normal. In fact, when I first reported it the head tech got a ride with me and he said that was odd and had my tranny replaced lol.. but then the same problem came back..
    Senior Member Two Rings sinful7's Avatar
    Nov 19 2006
    1994 Schwinn
    I thought the TC went into full-lockup in all gears in both sport and tip modes, and slipped in drive? I guess I've never really paid attention to the actual throttle response in higher gears in sport... I'm already driving so damn fast it doesn't really matter.
    As for this ATF change at 30k-
    I thought the ATF Audi uses is touted as lifelong fluid? Also, doesn't that stuff have to be IV-style dripped in to the tranny or something rediculous? If so, it doesn't make sense to change it every two to three years... what a PITA.
    Mar 20 2006
    Quote Originally Posted by sinful7 View Post
    My tuners at East Coast European told me every 80k miles is a good idea. It's about a $200 job.
    Dec 06 2007
    there is no lifelong ATF fluid that would only work if u drove in a perfect straight line and did not downshift by flooring it for example if u drove stopped and drove back that's it because not much heat would build up in the tranny.
    they say lifetime but it's bogus change it out once every 40k
    -Kirk
    Nov 19 2006
    1994 Schwinn
    While I agree that the 'lifetime' description probably means the standard 'lifetime' implication of 100k miles, I don't think it's necessary to change it every 40k. Heck, even on my old GM 700R4 changes weren't really necessary inside of 60k.
    Aug 26 2005
    Obviously, it not necessary, but that mileage is reasonable for the purpose intended. If the changes aren't frequent enough, there is little benefit compared to not changing it at all.
    The service conditions need to be considered in each case too. For example, if most mileage is city driving, then the change interval should be even shorter, like 30K miles. The reasoning is that for city driving the trans shifts maybe 500 times per hour where as on the highway, the trans shifts only once or twice per hour driven. Clearly, for the city driven case, the fluid is stressed a lot more, and the contamination from wear particles is much higher.
    Jan 28 2007
    dallas TX
    Also have to keep in mind if your changing out the filter or not... a dump and refill is good every 30 to 40 k... Cause i dont think u can drain out all the fluid theres still a remaining portion of the fluid still in the housing... so just draining and refilling is good habit just to keep it cycled... I noticed a big diff when i changed mine with redline atf shifts smoother and not even notchy in the least bit...
    Nov 03 2008
    Layton, UT
    I went to the dealer to get atf and a filter. The parts guy suggested not to change the fluid because the transmission probably has metal particles in it thats helping the transmission hold gears and if the fluid is changes it will be clean and possibly not shift at all. This is from his personal experience with his Mom's audi. What are your guys thoughts?
    Nov 19 2006
    1994 Schwinn
    My thought is... Yikes... Aren't parts counter guys supposed to be ASE or what? haha!
    He is recommending not changing a fluid because the inherent abrasive contaminants are vital to the reliable operation of the drivetrain. I guess Audi uses a metal-flake-infused ATF from the factory then?
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    yeah they use flakes, but if you add a 100 grit sand to it you'll get much better power transfer and quicker shifts.
    Mar 20 2006
    Quote Originally Posted by widgget View Post
    yeah, that grinding sound you get adds 10 whp
    Nov 03 2008
    Layton, UT
    So anyways, I talked to another ASE certified mechanic and he suggested that if the transmission fluid has never been changed, not to change it, too. My car has 125k on it. The transmission still shifts good, so it looks like I will just keep driving it the way it is.
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    Yea, i trust my parts guy at my local dealership with my LIFE! When i asked him for a transmission mount he turned the computer to me and just kept flipping the screen of parts saying " tell me when you see it."
    125k is a LONG time to not change your fluid... i cant believe what both of those guys told you *shakes head*
    Capt. Obvious: It's like fucking your cousin, just because you can doesn't mean you should.
    Nov 03 2008
    Layton, UT
    Yup, I can't believe it either, thats why I'm on here.
    I bought the car about a month ago and drives perfect, has all scheduled maintenance records, but never a transmission flush.
    So would a chip help the slight hesitation around 3800 rpm's?
    Feb 09 2008
    Austin Texas
    Just remember, our fuel filters are supposed to be lifetime too!
    Nov 03 2008
    Layton, UT
    lol, I'm picking up a new one tomorrow.
    Feb 09 2008
    Austin Texas
    Just pick up a tranny filter also
    Aug 26 2005
    The suggestion not to change the fluid, cannot be supported by the facts involved. I don't know how this non knowledge got started, but it has no merit. There is no factual evidence to form the basis for the "don't change the fluid now that it is contaminated and oxidized, and doesn't provide the benefits of new fluid, so that is what you want to run with" is illogical nonsense.
    No offense intended, but ASE Certification does not establish any credibility as a technical authority, does not represent any credential as a recognized expert knowledgeable with the specific aspects involved at issue here.
    Feb 09 2008
    Austin Texas
    maybe he is just ASE in brakes or something lol.
    Established Member Two Rings randylam's Avatar
    Jul 23 2007
    Hong Kong
    The cvt tranny has filters!
    where and how to change it?
    Aug 26 2005
    There is no evidence of fact of the alleged association between the wear metal that settles out of the fluid, (and there are four big magnets in the trans fluid pan, one at each corner to trap ferrous metal particles, mainly steel clutch plate wear particles,) or trapped in the filter, having a certain practical or essential role allowing the transmission to function if present, or cause the trans to fail if not present. That doesn't make sense. If that where true, then how did the trans work right from new?? (That is, without the alleged wear particles performing the key tasks and the basis for the overall operational capability of the trans.)
    Nov 03 2008
    Layton, UT
    Thanks for all the help everyone. I'm just gonna go ahead and change the fluid and filter. And if it doesnt shift after, i'll just put the old fluid back in.
    Mar 20 2006
    My guys at eastcoast european told me every 80k miles for my TIP. I trust them. It's about a $200 service.
    Aug 26 2005
    The procedure is somewhat more involved than used to be the case. You need a vag-com, and a hooked filler hose and a bottle pump. Also, the fill port plug is a large hex IIRC, it's 17mm. The car must be on a lift or jack stands and level.
    Do you have the bentley manual?
    Nov 03 2008
    Layton, UT
    Nope, I dont have a Bentley manual, but I do have a vag-com.
    Aug 26 2005
    I recommend the Bentley instructions for refilling the trans properly. See: www.ebahn.com for on-line manual access.
    Junior Member Two Rings K1200GT's Avatar
    May 10 2007
    OMG Not the "don't change the fluid or the world will end" old wifes tale again! I changed mine around 60K and it was UGLY! Wish I had done it sooner. It's easy to do, couple of car ramps and jackstands, VAG-COM and a cheap fluid transfer pump.
    I've posted links to the site for a trans change kit for like 100 bucks.
    Use the search
    I liked the parts guy comment about the trans mount and "tell me when u see it". Priceless!
    Only go to the dealership parts counter in utter desperation, with correct part number in hand. I prefer to order online and wait a couple days.
    Happy Holidays
    2017 A4 Quattro CYMC
    2022 Audi A5 Sportback 40 Miller cycle (Wifes car)
    2011 Audi A4 Quattro stock SOLD
    2002 Audi A4 1.8turbo Quattro Tiptronic SOLD
    APR 93 chipped
    BKR7E's, 710N
    Bilstein HD dampers (struts)
    K&N panel filter, modified stock airbox
    Senior Member Three Rings rocketheavy's Avatar
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    where the heck is the filler? i took a glance today when i changed my oil but it looks like a tight spot.
    03' 1.8T Tiptronic
    Baileys DV, 15% tints
    Ziza yellow Fogs
    Blacked out grills/trim, De Badged
    Apikol snub mount, clear corner mod
    A6 engine mounts
    Aug 26 2005
    Quote Originally Posted by rocketheavy View Post
    It's up inside the verticle well in the trans oil pan.
    Aug 26 2005
    My definition of "lifetime filled fluid" is where the "lifetime" is until the trans fails.
