Results 1 to 8 of 8
    Established Member Two Rings bigredx24x's Avatar
    Sep 23 2008
    06 25quattro s4, 95 Ford Rgr, 05 sv650
    DC
    Car won't start - won't crank
    So, I come out yesterday from work to go home and try to turn on the car and it wouldn't start. What's more is that it would not even try to turn over - no cranking. The battery seemed fine (all interior lights came on, radio, and headlights) and I even attempted to jump it just in case...nothing. Being that it was 30 degrees out and nighttime and the car is still under warranty, I just called Audi Roadside and had 'em tow it to the dealer.
    The guy at the dealer said they thought it might have been the clutch switch, but they tried that and it doesn't seem to be the problem. However, they said there is something wrong with that clutch switch circuit that they will have to troubleshoot.
    Anyway, just wanted to see if anyone else had something similar happen to them...
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    Re: Car won't start - won't crank
    This seems to be a cold start issue when it gets cold out. The starter or the starter solenoid seems to get locked up and you need to get the car to warm up to start. You see alot of this around this time. Good luck getting Audi to fix it. They are going to plug into the car tell you that without a code there is nothing they can do. The worst part about this is that fact that there is no way the car can give you a CEL for the starter solenoid. Some dealerships seem to know about this others just don't know what to do.
    Veteran Member Three Rings 3 bar's Avatar
    16 SQ5, 14 A7 Tdi, 91 Corrado, 02 Passat wagon, 99.5 A4 TQM
    Greensboro NC
    Quote Originally Posted by bigredx24x View Post
    Check my write up on "car wont start for 30 sec to 3 min WTF?"If you need help replacing the starter let me know. I live right up the road from you.
    2004 Atlas Grey A4 Avant
    1999.5 Volcano Black Audi A4 1.8TQM
    2002 VW Passat wagon 1.8t 5 speed
    1991 VW Corrado 1.8t w/matching trailer Waterfest 03/04 winner (show)
    1980 Chrysler Cordoba LS 371ci 450hp 12.68(go)
    Sep 23 2008
    DC
    Quote Originally Posted by 3 bar View Post
    OK, thanks 3-bar, not sure how I missed that post...
    I'll be in contact if the dealer doesn't fix it.
    Sep 23 2008
    DC
    Quote Originally Posted by Justincredible View Post
    I'll check w/ the dealership Monday and see if they have troubleshooted the solenoid, thanks!
    Sep 23 2008
    DC
    So, got back the car today, but wasn't able to get there in time to talk to the service associate. I know that they replaced the starter, but not sure if they replaced the solenoid. I am a little worried that it just "worked" and the problem wasn't really the starter, but that it was the solenoid and they didn't replace it...so, we'll see i guess.
    Actually, HBL Audi in Tysons replaced it for free under warranty.
    Last edited by bigredx24x; 11-24-2008 at 08:38 PM. Reason: added part about it being covered under warranty
    Jul 24 2008
    chicago
    wait till the first real cold day you will know if they fixed it or not
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    Im sure they would replace everything or the solenoid as that is much cheaper than the starter.
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
