Results 1 to 40 of 46
Thread: New best
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    New best
    well in the 1/8th mile and 60 ft.
    Video pulling 1.54 60 ft and 6.94 at 103.3 mph. The car in the other lane is a old toyota celica which ran 11.0 at 135 mph with a 1.9 60 ft and a better reaction time.
    Just went there to test the new shift light which is set to 8200 rpm. Was also testing to see if I can run more then 32psi but no matter how much I turned up the EBC the boost would not go any higher. Put the EBC back to 32psi and made that last run launching hard to the 1/8th.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: New best
    Damn dude, good pull.
    Jul 07 2004
    socal
    Re: New best
    Thanks. I figure I was on pace for a 10.6 if I would have stayed in it, sad part is that I still ran 11.2 and might end up getting kicked out of the class. Well I wont know till tomorrow.
    I had to make one hard launch, my other 3 runs were rolling off the line with 2.2-2.4 60 ft times. I have those on video too.
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    Re: New best
    Nice run and video
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: New best
    The 6.94 lines up w/ about a 10.7-10.9 time, but that's for most N/A applications.
    I wanna hit a 1.5 60' dammit
    Active Member Four Rings
    Dec 11 2006
    Boston
    Re: New best
    Nice 60'.
    You need to learn to shift faster.
    Stage 3+ RS6's
    Senior Member Two Rings tonelee1316's Avatar
    Oct 10 2006
    rancho cucamonga
    Re: New best
    where was this at? california?
    Genesis Autosport
    Evolution Racewerks
    Jul 07 2004
    socal
    Re: New best
    Quote Originally Posted by tonelee1316 View Post
    Right in your back yard at fontana. It runs tomorrow too.
    Quote Originally Posted by djwimbo View Post
    For AWD it is around 1.53-1.55 x the 1/8th ET depending on how much power the car is making and if it is setup to finish at its peak hp. My old best was 6.96 and ran 10.69.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: New best
    The 1.55 seems to be the most common multiplier.
    are you hitting a full 32psi in 2nd gear, or only once you hit 3rd?
    Jul 07 2004
    socal
    Re: New best
    I will have to check my logs of that hard launch, my other runs were only part throttle off the line. When I go WOT in 2nd gear on those runs I hit 32psi in 2nd.
    Let me know what you think I hit in 1st gear on the video, 30psi is at 3 o'clock, 35psi at 4 o'clock and 40psi at 5 o'clock on the gauge.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: New best
    I guess I wasn't looking before, but it looks like the 25-30psi range
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: New best
    Uber slowness...
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: New best
    jeez why didn't you just carry the car at that speed...
    Nice runs. you definitely gotta work on the cage fund though so you can really get on it.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Aug 05 2008
    Highland
    Re: New best
    is anti-lag not setup on your car yet or something?
    Oct 27 2007
    In the lab
    Re: New best
    He's against antilag Johnny lol
    Aug 05 2008
    Highland
    Re: New best
    really?
    im assuming he'll elaborate once he sees this post....
    Jul 07 2004
    socal
    Re: New best
    Quote Originally Posted by zerb View Post
    really?
    It has been setup since 034 installed my IIc a few years ago, I just dont use it anymore since I can pull 1.5 without it.
    Aug 05 2008
    Highland
    Re: New best
    now what about getting real nifty and setting up the anti-lag to work between shifts so that the turbo lag is virtually eliminated. im just throwing ideas out there cause when youre running 10.6, im gonna guess every little advantage could help to get that 10.5 or better...
    Dec 11 2006
    Boston
    Re: New best
    He seems to have the ability to run sans anti-lag. 1.5 60's is pretty impressive.
    What is the tire setup? I assume you are still running the 17" SL's.
    Stage 3+ RS6's
    Oct 27 2007
    In the lab
    Re: New best
    Yup, still the SL's with DR's...
    He wants a lighter 16 setup with some better tires
    Dec 11 2006
    Boston
    Re: New best
    Needs hoosiers and MB CLK wheels.
    Stage 3+ RS6's
    Oct 27 2007
    In the lab
    Re: New best
    He needs M/T wrinkle walls and Weld Racing wheels... LOL
    Jul 07 2004
    socal
    Re: New best
    Hard to do that when shifting at 8k+ rpm. Right now I never get out of boost during normal shifts and there isn't really any lag.
    Plus I like not having to replace the tranny every time I go to the track. In 8 years of drag racing this car I have only had to replace 1 trans and right now I am running my OEM 1.8 trans that came with the car.
    Oct 27 2007
    In the lab
    Re: New best
    I stockpile trannys in anticipation... They are cheap enough
    Jul 07 2004
    socal
    Re: New best
    Well you better because plenty of B5's have blown stock trannies while just making 400whp.
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    Re: New best
    You need to throw that shifter, srsly maybe workout to improve those forearm muscles.
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Jan 25 2006
    A4 2.0T
    MD
    Re: New best
    Quote Originally Posted by 317ssayzarc View Post
    For some reason o1a trans are cheap in RI ----
    My current trans is from RI haha.
    Registered Member Three Rings kovalevandrew's Avatar
    Oct 19 2008
    South Africa
    Re: New best
    That's pretty sick dude.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: New best
    Well, Mike had been letting it rip all day today, first pass this morning (final qualifying) was 10.7 @ 136 spinning through first...
    Then in the first pass of eliminations he went 10.5 @ 133 with a 1.5x 60 foot.
    Oct 27 2007
    In the lab
    Re: New best
    Haha, I got that text message a few hrs ago, thought he was done after that...
    But I guess they let him come back and he ran a 10.5 eh? What was the ET exactly? 10.xx?
    Jul 07 2004
    socal
    Re: New best
    Here are those 2.
    1.672
    7.052 at 107.63
    10.727 at 135.67
    New Record run
    1.576
    6.823 at 107.16
    10.553 at 132.35
    I still need to upload the vids, cut them down and load them onto Streetfire. Once I have all that done I will post up a new thread. One of the other racers in my class had a friend doing vids from the stands and said they would post those up on Youtube or Streetfire.
    I was runner up and took home $200.
    Veteran Member Four Rings MultiAudis's Avatar
    Mar 12 2006
    01 Allroad 6mt, 01 A4
    NoVa
    Re: New best
    Congrats Mike, that's just sick!
    Oct 06 2004
    Minnesota
    Re: New best
    Nice runs. Get those videos up asap
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Re: New best
    Mike, if you need a tougher tranny, look no further than the venerable old 016.
    It was the 5-speed fitted to all type 85 (B2) models, as well as the type 44 (C3).
    You won't bust one of those, they're also tougher than the 01E 6-speed.
    Jul 07 2004
    socal
    Re: New best
    Quote Originally Posted by Siena View Post
    Thanks for the info. Maybe it will be something I will have to look into when I try to make more power if my stock trans cant handle it.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: New best
    Nice run, 10.55 isn't slow.
    Senior Member Three Rings bernB5's Avatar
    Nov 13 2007
    Long Island, NY/ Hartford, CT
    Re: New best
    here you go.. 10.5@132.. pretty sweet
    http://videos.streetfire.net/video/F...-at_201467.htm
    Old: 97 30r'd A4 ---> headaches
    New: Evo IX MR ---> 354awhp/349tq and couldn't be happier
    BERNSTEINphotography
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Re: New best
    congrats Mike, nice runs
    my best 1/8 mph was in the 102's
    107 is very fast
    I wish I lived more south, it's almost Winter over here
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    http://www.youtube.com/watch?v=1kG98vSWkT4
    WATERFEST 15 RUN 10.92 @ 133.55 mph
    Jul 07 2004
    socal
    Re: New best
    Quote Originally Posted by GURUMAN View Post
    107 is very fast
    Thanks. Well you can always come down here and run with me in 80 deg temps during Nov.
    Senior Member Two Rings EuRoSp1c's Avatar
    Nov 04 2008
    Jersey
    Re: New best
    i would have loved to see that run from outside view
