Results 1 to 6 of 6
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    aftermarket headunit help.
    Ok. I'm a b5 a4 owner and have been on audizine a while. But my girl bought a 225 tt quattro roadster and I got her an in dash single din flip out screen/radio and am having problems wiring it. We got the wire harness, amp integration kit and dash kit.
    I connected all the wires to each harness but am not getting power OR sound. The pinouts on the harness seem to not match up with the pinouts of the plug coming from the car. I have been reassured that I have the correct harnesses for my MY. I'm on my phone now but when I get home I will post pics of said harnesses and the headunit as it sits now. Any help would b appreciated as I would like 2 get this thing up and running.
    Edit: all the diys I have seen, the car has 4-5 plugs coming from the car. Her car only has 2 black plugs and the antenna wire coming from the car............
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Registered Member Three Rings VagStaR's Avatar
    Oct 03 2008
    04 A4 tqm. 99 saab 93 2.0T 5sp
    York, PA
    Re: aftermarket headunit help.
    I had the same problem with my 04 A4. I had a pioneer DVD player, and it wouldn't power on after everything was done. I searched around and found out that I had to run the red power wire, I think it was, seperatly directly to a fuse. Which I did and it turned right on after that!
    Sep 01 2005
    Ya its a pain 2 install because of the factory amp. Hopefully someone that's done it on a tt will chime in. There's. Gotta be someone that's done it!
    Sep 01 2005
    wow. lots of help over here on the tt forum huh?
    don't everyone help me at once.
    Senior Member Two Rings roTTirocket's Avatar
    Mar 18 2007
    02 Audi TT 225QR, 96 C36 AMG
    Hayward, CA
    tt forums suck on AZ.its nothing like the a4 community on here..you should rather go ask on the audiworld forums, the TT people over there got everything down.
    Instagram: Rysidhu
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Get a metra adapter harness and VOILA.
    Installed a Clarion ZX675USB in my 2000 TTQC w/o fanfare. Go the AudiWorld TT Forum FAQs HERE and get it going on.
    I kept the factory amp and speakers: they are more than adequate at mty age. I can rock the neighbors just fine on "33", and got plenty of clarity and bottom.
    Crutchfield is your friend.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
