Results 1 to 15 of 15
    Veteran Member Four Rings Dodge2Dub's Avatar
    Feb 18 2007
    E90 M3; Ducati S2R 1000
    San Diego, CA
    Stoptech 4 piston 355mm vs. stock 345mm
    Anybody care to comment on the differences? Are the Stoptech's worth the money? Any noticeable difference on the street?
    Cool stuff with a little growl!
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Re: Stoptech 4 piston 355mm vs. stock 345mm
    With the Stoptech setup you get a better caliper design, fixed vs. sliding, and 2 more pistons to help disperse the pressure onto the brake pads.
    Will you 'feel' a difference on the street. That is objective as usually the upgraded brake pads bite better than the stock pads you have right now.
    I'd suggest upgrading your pads, fluid and lines before getting a BBK as you are in BBK size territory and those upgrade will be quite noticeable and cheaper.
    Feb 18 2007
    San Diego, CA
    What pads/lines/fluid do you recommend? I'd like to retain the thickness sensor. Also, i heard that the SS lines dont do much in terms of stopping power or feel. Ed, please feel free to jump in.
    Jun 11 2005
    Vancouver, BC
    Pads? For street Hawk HPS or HP+ I found to be good with low dust. If you want something more aggressive try a Ferodo DS2500. Once again... the pad choice is very subjective as it needs to match your driving style and braking habits.
    Fluid? Motul 5.1 or RBF600
    Lines? You can do this last if you find the pedal feel too mushy. Goodridge or the Stoptech lines are good options.
    Veteran Member Four Rings s6sputnik's Avatar
    95 S6 rs2//13 A6 3.0T//12 S4
    Austin Texas
    I'm with Winston do your fluid first. The modern S4's have great brakes. I just did a weekend at Texas World Speedway with many 135mph to 50mph stops and I had NO fade!!
    I did a BBK on my other car as I put Porsche 996tt brakes on my urS6 but those cars came with little lousy brakes, and it is a pita to do BBK's.
    Upgrade the fluid and pads!!
    Shawn
    2222 & 620 Austin TX
    // 95 S6 RS2 // 13 A6 3.0T // 12 S4 3.0T
    Feb 18 2007
    San Diego, CA
    How much better are the Hawk HP Plus compared to the Hawk HPS? How about the Hawk ceramics?
    Also, where do you guys buy your SS lines and fluid? ECS sells the Hawks at what looks to be a good price.
    Veteran Member Three Rings FourRingRider's Avatar
    Nov 04 2008
    911 Turbo
    Jacksonville, FL
    I have braked pretty heavily during some spirited driving and it definetely felt like the stock brakes could be improved...
    I think a lighter weight 2 piece cross drilled rotor set, and new pads would do the trick... and finish it off with new stainless brake lines... Ive always liked the quality of Goodridge... who carries them for the B7 S4?
    Jun 11 2005
    Vancouver, BC
    Ceramics would bite the least and last the longest. HPS is good for the street and the Hp+ is about the same but gets better as they get hot.
    You can get the good from most of the AZ advertisers here.
    More aggressive pads and upgrade the brake fluid would hep your situation.
    Crossdrilled rotors will actually make it worse as you are losing metal which you need to absorb heat from braking.
    Veteran Member Four Rings S4DTM's Avatar
    May 26 2008
    '12 TTRS, '01 S4 Full 3.0L Racecar
    Moraga, CA
    From what I've heard, the Stoptechs aren't really any better than the stock setup. You're adding a few pistons to the menu (and 1mm), but apparently the feel isn't any better. I agree with the rest of the guys on upgrading your fluid to Motul and the pads to Hawk. If you're gonna do a BBK, I'd honestly say save your money and go with the STaSIS Alcons
    [COLOR="red"]l FRRG Northern Ring President l
    '17 Alfa Romeo Guila Quadrifoglio
    '01 S4 Racecar "Giggles" - Sponsored by 034Motorsport
    Four Rings Racing
    Gone but Never Forgotten:
    '07 S4 DTM
    ->'12 TTRS - Phantom, Titanium, CF Mirrors, Sport Exhaust, Tech, Butt Warmers, Tint and Clear Bra, APR Stage 1, 034 Midpipes, AWE Boost Gauge
    Feb 18 2007
    San Diego, CA
    Any recommendations for rotors?
    Veteran Member Three Rings Bpitz15's Avatar
    May 07 2008
    Hartford County, CT
    JHM has just released a new two-piece lightweight rotor. Look into that.
    Items for sale PM me for details:
    A6/Allroad 4.2 V8 top end
    Feb 18 2007
    San Diego, CA
    Quote Originally Posted by Bpitz15 View Post
    Do they make solid products?
    May 07 2008
    Hartford County, CT
    http://www.audizine.com/forum/showth...M+Brake+Rotors
    i have their short shifter and i think it is a very high quality product.
    Here is the thread they started here. They can also do slotting and or cross drilling to give your brakes an BBK look.
    Feb 18 2007
    San Diego, CA
    Thanks! I sent them an e-mail with a few questions. 20lbs of unsprung weight savings...wow!
    May 07 2008
    Hartford County, CT
    Good Luck!
