Results 1 to 19 of 19
    Saint Cloud, Fl
    What is needed to run a larger throttle body ?
    1st and foremost I searched an was unable to come up with definitve answers
    - So basically I want to know what it would take to bolt up a larger throttle body. Yes I am aware of Issams new Intake, but I dont want to go that route just yet.
    This is what I found
    - You will need some sort of adapter plate
    - Yet I've also read that you can simply bolt up certain TB's
    The options
    - VR6
    -S4
    -RS4
    -I.T.B'S ?
    instagram ------------> low_enforcement
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Re: What is needed to run a larger throttle body ?
    Pretty much it is an adapter plate and that's it.
    To take full advantage of the bigger TB you will need a bigger plenum intake manifold and adjust the SW to take advantage of the extra air.
    Saint Cloud, Fl
    Okay I read that Issam sells an adapter plate, but I wan unable to locate the plate on the 034 website.
    I purchased a spare AEB IM and I plan to let my local turbo guy do the whole plenum thing.
    Jun 11 2005
    Vancouver, BC
    Hit Issam up directly for the plate.
    I have one ordered for the 80mm VDO TB I bought of him earlier this year.
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Quote Originally Posted by 7speed View Post
    http://www.034motorsport.com/product...roducts_id=570
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Dec 06 2007
    could u please explain the process i'm curious.
    -Kirk
    BetaAlphaTau Member #58
    Saint Cloud, Fl
    VDO ?
    Saint Cloud, Fl
    thanks
    Dec 06 2007
    ^^no the Plenum thing for the AEB IM
    -Kirk
    Saint Cloud, Fl
    Sorry I can help you there. My best educated guess is that they simply cut off the existing plenum and make a new larger internally smoothed plenum
    Jun 11 2005
    Vancouver, BC
    VDO ?
    Issam had a few of these new 80mm VDO TB for sale a while back and aI snapped one up as it was something I knew I'd look into as my build progressed.
    It's still sitting in the box waiting for it's moment to come out.
    Saint Cloud, Fl
    oh okay
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    For starters, a turbo big enough to take advantage of it. No one has maxed out the TB on a B6 and a 3071/76 isn't going to do it. If you need to upgrade to a bigger TB, you'll need a bigger IC and piping also. Having all 2.5" pipes and a 3" TB is dumb.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Quote Originally Posted by AudiA4Turbo22 View Post
    Here's a few pics of the process.
    Jun 29 2007
    Raleigh, NC
    ^damn you beat me to it, i was about to say "ask john about that "
    that thing looks good man, can't wait to see how the car performs now.
    and chris - while a 3071/76 may not be maxing out the TB/IM, you know that you're still going to see gains with larger/improved designs on both parts.
    and yes, 2.5" piping to a 3.25" TB is dumb. that's why my entire cold side is 3"
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Saint Cloud, Fl
    wow that IM does look nice.
    B6Lovin - is the outlet of your FMIC cold side 3" or did you just change it to 3" piping ?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    3" IC pipe is not needed till your making 1000chp. You there yet?
    I dont even run a 3" IC pipe, because it reduces velocity and that increases lag. So going too large doesn't actual get more air to the IM.
    Oct 29 2005
    10speed
    San Francisco, CA
    John, that shit is baller
    - Clint
    Dec 06 2007
    Quote Originally Posted by Condo View Post
    Thanx John if u don't mind me asking how much did that run u? What turbo are u running? and did u see any gains? thanx
    -Kirk
