Results 1 to 13 of 13
Thread: Turbo Leak?
    Veteran Member Three Rings msharifi's Avatar
    Aug 13 2008
    Orange County Cali
    Turbo Leak?
    Hi Everyone,
    I have a issue when I turn the car on in the morning there is a loud noise coming from the turbo/CAT area. Would a turbo leak or CAT leak cause that? its fine after 2-3 mins when the car gets warm up.
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    Re: Turbo Leak?
    you sure its not the secondary air pump..
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Aug 13 2008
    Orange County Cali
    Re: Turbo Leak?
    where is the secondary air pump?
    Also does the K04 turbo fit over OEM K03 turbo for replacement?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Re: Turbo Leak?
    Quote Originally Posted by msharifi View Post
    The secondary air pump (SAI) is located at the lower front of the motor. Its function is to pump extra air into the exhaust (through the combi valve located on the back of the head) during a cold start. It usually engages for about 90 seconds. Its function is to help protect the catalytic converter during a cold start. Your noise may be coming from a leak around the combi valve. It is the silver round device in the pic with the blue hose attached.
    And yes you can direct replace the K03 with a K04. You will need different software and injectors.
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    Re: Turbo Leak?
    i would guess it was the secondary air because mine makes that noise too when i start it and i have an engine code for the secondary air
    Aug 13 2008
    Orange County Cali
    Re: Turbo Leak?
    What is the fix on this? I do have a bad MPG even after I changed my first O2 sensor. It did improve a little bit but not whole lot. I'm half tank of gas and its been 120miles to half tank.
    See the pic below the problem I have
    Jun 08 2008
    Calgary AB Canada
    Re: Turbo Leak?
    put a hose clamp on that?
    you might have an issue with some vaccum valves if theres so much pressure in there to pop it back out.
    when you open youre oil filler cap while the engine is running, is there excess pressure?
    Aug 13 2008
    Orange County Cali
    Re: Turbo Leak?
    There is already a clamp but the metal part comes out not the rubber that is already clamped.
    I'm trying to figure out why I get that loud noise and very low boost I get about max 10 PSI and goes back to like 7psi.
    Dec 28 2006
    Western Maryland
    Re: Turbo Leak?
    The metal nipple is pressed into the valve cover and is not supposed to come out. You might want to pull the hose off and then try tapping it back into the valve cover. What you are describing now sounds like a serious boost leak. Probably a split hose somewhere. first thing I would recommend is a boost leak test.
    Aug 13 2008
    Orange County Cali
    Re: Turbo Leak?
    How do you do the boost leak test? The DV Vaccume lines are good
    Jun 08 2008
    Calgary AB Canada
    Aug 13 2008
    Orange County Cali
    Re: Turbo Leak?
    Other then that because I dont have a air comprasser.
    Aug 13 2008
    Orange County Cali
    Re: Turbo Leak?
    When its making the loud noise at cold start it means its not pumping? is it only used at cold start? does it effect your MPG as I heard from others?
