Results 1 to 40 of 44
    Nov 15 2008
    Aurora
    What is the best gas to run in Audi A4s
    Just bought a A4 a few weeks ago...2005.5 2.0T. First Audi I've owned. wondering what is the best gas to run in these cars. BP, Phillips 66, Mobile, Shell, etc.? I have always used BP in my cars in the past. but some gas runs better in some cars than others.
    Senior Member Three Rings jrok24k's Avatar
    Feb 19 2008
    B7 A4
    Re: What is the best gas to run in Audi A4s
    i personally use shell v-power 93
    DUH! an Audi
    los angeles, CA
    100 octane is the best!
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    race gas!!!
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Senior Member Three Rings khmerguy978's Avatar
    Sep 14 2008
    B8 A4 Prestige
    Boston, MA
    i'd avoid diesel. but that's just me.
    premium gas is what the car requires.
    cheers... rocco
    B8 A4 Prestige
    Wrangler Sport
    CBR600RR
    Prelude
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    leaded race gas
    Dec 11 2006
    Boston
    Shell
    BP sucks.
    Stage 3+ RS6's
    Veteran Member Four Rings AWDTURBO's Avatar
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    anyhting 93 and up !
    Veteran Member Three Rings Latin Audi's Avatar
    Mar 18 2008
    '63 & '75 Nova
    Texas
    shell v-power!
    Brilliant Red 2005.5 A4 2.0T Quattro 6MT
    APR 93 | Evoms CAI | RS4 Sway | CC | De-Badge | ECS Snub Mount | 5%| Ziza City Lights
    Veteran Member Three Rings kharsnett's Avatar
    Oct 24 2006
    Indianapolis IN
    93 bp or shell for me
    B7 A4 Non sline Sline Edition, High flow fog light holes, Titanium license plate screws, Cross drilled lug bolts, greasy axle, Coolant relief valve on cylinder head, Pressure relieving boost hoses, Cylinder Head Exchange program, Custom cam grind, used fuel pump follower, variable geometry front Control Arms, Automatically shifted manual transmission, 87 octane APR tune, detuned 83 Octane APR tune, Custom high flow Flex section, Custom built spark plugs, Ebay sponsored!
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    According to my local newspaper (article is probably nationwide), BP's Invigorate has patented mix of additives that help the car running smooth better than Shell V-Power (93 octane). I would recommend BP or Shell only has they run as the high tier gases with the most amount of additives for keeping your car running optimally. In other words... go with either gas... but shouldn't go with anything else... why go to McDonald's when you can go to Wendy's? lol... bad analogy
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    Go back to your audi dealer and ask for a "Before you fill up, you should know about top tier gasoline standards" card. it tells you which gas companies you should use. Shell is the only one around me that makes the list, so i go there. Sunoco Canada makes the list but not the one in USA so that is my backup as i've always used Sunoco 94 when it was available. BP Amoco seems to be good gas and i use that as my cheap alternative. see toptiergas.com for the info as well
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Established Member Two Rings Element's Avatar
    Aug 09 2008
    New Jersey
    The cheapest 93 gets me from point A to B just fine
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    Shell V-Power FTW! Plus, I can collect Air Miles.
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Senior Member Three Rings kastro's Avatar
    Mar 20 2008
    04.5 1.8TQ Tip A4 Black -
    Ottawa, Ontario
    shell v-power in canada is 91.. u guys got 93?
    Veteran Member Three Rings sdjeff's Avatar
    Jun 04 2008
    B7 A4 2.0t, Dino 246 GT
    RSF san diego
    love shell v-power
    Veteran Member Four Rings gods_kitchen's Avatar
    C16
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    any mom and pops regular gas should be good lol
    on a serious note, i use BP 93, i like it, or if not id find some leaded race gas, but only if you remove your cat
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Quote Originally Posted by gods_kitchen View Post
    C16
    Prologued use of leaded gas should be avoided, since the fuel filter does not like it very much.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Oct 14 2006
    MK6 Jetta
    South,FL
    VP FTW !!!
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    does it really matter? i go to whatever's close when i need to fill up with 93.
    Senior Member Three Rings GhostSquadGarage's Avatar
    Jul 05 2008
    SLR32 \ IS300
    E85 all the tahoe's are doing it !
    Oct 29 2007
    So. California
    Out here in cali, I've used nothing but Chevron 91 in my cars since 2004.
    Veteran Member Three Rings Bryan's Avatar
    Mar 20 2007
    Vancouver
    Shell V-power..... or petro-Canada...
    Bryan K
    06 B7 A4 - Slightly Moded.
    09 8P A3 - Slightly Moded.
    10 B8 A5 - Slightly Moded.
    11 B8 S4 - Milltek exhaust, H&R, BFI spacers.
    Registered Member Four Rings
    Jun 14 2007
    2007 A4 2.0T QM 2008 A8L
    New York
    Quote Originally Posted by Element View Post
    Shell is cheaper than other big brands and considering how much of it flows through your engine I like the piece of mind knowing this gas has been rated to be better quality.
    Veteran Member Three Rings Subaru71's Avatar
    Jan 15 2008
    2010 DGM Impreza WRX
    Chino Hills, CA
    Audi's warranty only covers your vehicle I think if you use their recommended brands. They're recommended brands, of course, are the good brands. (non-cheap)
    Chevron/Texaco, ExxonMobil, 76, Shell
    Please add if I left out something
    2008 Phantom Black TQM
    Established Member Two Rings Quattro06's Avatar
    Aug 11 2008
    2006 Quartz Gray A4 2.0T
    Dublin, OH
    Nothing less then Shell V-Power for my baby! BP will kill yours in my opinion they add to much crap you dont need.
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Quote Originally Posted by Quattro06 View Post
    Are you sure you're not talking about SA?? BP 92 is the best stuff we get here in MN. Shell v-power 92 is nice but BP seems to be what every car that has something done to it uses.
    The usual things!!
    Resistor Install
    Veteran Member Four Rings Louis J.'s Avatar
    Dec 26 2007
    PNWR
    Chevron 94 only and always.
    Black B7 Titanium - Sold
    APR93 | Carbonio | Vogtlands | RS4 sway | Abt quad-tip | Podi | BBS RCs w/RT-615s | RS6s w/W300s
    Veteran Member Four Rings eskimopunk's Avatar
    Mar 26 2008
    63 Ford Falcon Futura Convertible
    Las Vegas
    chevron 91 and shell when i can afford it... i used to add a bit of rebel 100 every now and then but i stopped when it got to $6 a gallon lol.... i should check it out again now. (vegas has shit octane lol)
    flickr
    "ALL I REMEMBER IS ARGURFIN WITH DRCURITY AND THEM KICKING me out of neptunes i ve had like 6 LIT's biches is crazy my backj fucking hurts" - El_Chapusca
    SBSC Designer
    For awesomeness. Thanks Pat.
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    Quote Originally Posted by Tiesto View Post
    shell is the most expensive around me. The cheapest here is Getty/ no name gas stations that I don't hesitate to go to if their price is right.
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Mar 24 2008
    I usually go with Shell or Mobil, the Shell station is right outside the plaza I work in, and the Mobil is right next to my gym, so it's only because they are right there, and 93 octane always. I've yet to find a station in CT with 100 octane, but I'd def throw it in to see the difference if I could find it. My buddy who has an M3 says that Shell is the brand that they recommended to him, so I'm sure it's at the top of the list as others have said.
    Veteran Member Three Rings quattro.it's Avatar
    Mar 24 2008
    2004 BMW R1150RT
    Bellevue, WA
    I prefer Shell V-Power over Chevron Supreme. Car runs better and has slightly better fuel economy that's why I only run these two brands.
    2007 A4 2.0T quattro Tip S-Line Titanium / Lava Gray / APR 91 /
    Sep 02 2008
    Boston, MA, USA
    I use Shell or BP. Usually BP because there are only 2 Shell's near me and i don't drive by them often. I would also use Chevron if they were in PA. There's also a chain quik-e-mart type place around me called Turkey Hill which was just recently added to the Top Tier list so i go there if i'm desperate (they all over the place)
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    I've tried just about everything .... and Shell Vpower has the best power to MPG .. Chevron is a lil bit better on the mpg .. but not enought for me to switch from Shell .. you can feel the difference in power.
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Veteran Member Four Rings Six Speed Turbo's Avatar
    Feb 09 2007
    Hopes, Dreams, Tools, Car Parts
    Killeen, TX
    I believe the owners manual recommends Shell VPower, I usally use Chevron but when that is not available I use Shell.
    2016 S3 Prestige - Glacier White Metallic, APR Stage 3+, APR TCU upgrade, APR CAI, APR FMIC, APR Catchcan, APR Lowering Springs, P3 Guage
    YouTube Channel https://www.youtube.com/channel/UC88...LbgXXvRHPvW3Xw <---SUBSCRIBE
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    BP 93 only, they give great gas card rebates and are everywhere on the east coast with competitive prices lol
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    all you guys using cheap 93 and see what happens in the future when u have engine problems. i use Shell V-Power and the only other gas i would use is Sunoco and thats because they have the highest street octane avalible(higher than 93 but cant remember what it is 95-96 maybe).
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    ^^I guess you didn't hear about Sunoco getting sued over adding too many things to their gasoline and it being diluted? Sunoco sucks horribly, never use it, ever
    Sep 28 2008
    Illinois
    What would happen if you use below 91 or 93?
