Results 1 to 37 of 37
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    DDM HID problems!!! /gasp
    So, my 6000k 55w HIDs are giving me a little problem...
    To be more specific, the driver side bulb sometimes doesnt start when i turn it on. I have to turn the key off and on a few times to get it to fire up then it stays on.
    It only does it after i drive a while then go to restart the car later.
    I figure its not the fuse, but i have no idea what it could be. Its also like 20 degrees out so i want to figure out the problem before i got and take stuff apart.
    could it be a bad ballast or what?
    __________________
    May 08 2007
    aeb 2.0bt, 00 bagged 1.8, 93 s-10
    jacksonville, nc
    Re: DDM HID problems!!! /gasp
    this just happened to mine. i switched the driver and pass. side bulbs to make sure it wasnt the bulb itself, it turned out to be the ballast. try that
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    UPDATE!
    I checked it out, and both of my ballast, which were mounted in the ballast holder on the bottom side of the headlamps, both popped out and the driver side was hanging almost near the ground. I think i can attribute this "dislocation". I took both headlights out and used the rest of my Silicon sealant as glue and pasted those bitches into the holders.... They're drying as we speak, so when i reinstall my headlamps tonight/tommorow, it will be the final test.
    __________________
    Veteran Member Three Rings b5andm3's Avatar
    Aug 22 2008
    Central Maryland
    You people need to start questioning yourself before you question a product you bought.
    Veteran Member Four Rings 4A Play's Avatar
    Jun 12 2008
    Allentown PA
    Should have bought VVME. Sorry, always wanted to say that lol.
    Self made, NOT Mommy paid.
    2001 1.8 qtm, GT2781R, 680cc Siemens, 3" turbo back, Autopower, Mafless Stage 3 Unitronics, Tial 38mm external wastegate, STS, Corbeau seats
    Registered Member Three Rings VagStaR's Avatar
    Oct 03 2008
    04 A4 tqm. 99 saab 93 2.0T 5sp
    York, PA
    Are those VVME kits even any good? I am a firm believer in, you get what you pay for, and those thing are like $40.00 haha. Did you get a bulb out light or anything. I have actually been looking at the MTEC kits on ebay.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    i've had vvme for almost 2 years. christmas would make it 2 yrs. no issues at all and i have a set in the projectors and a set in the fogs
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Senior Member Three Rings erode's Avatar
    Nov 07 2008
    05.5 B7 S4, 98 E36 M3, 03 E46 330xi
    MN
    DDM is good... used their stuff for years in my M3s with no issues. If I ever have issues I can always attribute it to my own idiocy.
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    nah DDM is legit. It was just i put the ballast in a dumb spot and it wasnt secured!
    Its working fine now lol
    Just curious, where does everyone mount their ballasts
    __________________
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    I don't get how the ballast being lose would cause the problem. Every time I have had the issue you are describing it turned out to be a bad bulb. Ballast are pretty much filled with solid glue/silicon. Yeah you want them secure, but being loose should not have that effect.
    Aug 22 2008
    Central Maryland
    Quote Originally Posted by le91688 View Post
    So why title the thread DDM hid problems. You're attracting negative attention to their company when its not warranted.
    Maybe a mod should change the title to "OP Shouldn't install electronics again"
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Quote Originally Posted by b5andm3 View Post
    Maybe because i had a "Problem" with a "DDM" hid kit.
    __________________
    Nov 07 2008
    MN
    It's ok, I don't think a thread like this defames or libels DDM ... issues occur with all products. People who care will read this thread and figure out what the issue truly was.
    Aug 22 2008
    Central Maryland
    Because of user install error. Go soak a $200 waste of money HID kit in water and check back.
    2000.5 A4Q - 2871r / 1.9L Stroked / IE Rods / JE Pistons / 3.5" TBE Exhaust / Forge MBC / 630cc Injectors / Walbro 255lph Fuel Pump / VR6 MAF / Unitronic Tune / CM FX600 / ECS N75 Race Valve / ECS 9lb Alum Flywheel / Forge TIP / Forge DV / ARP Head Studs / BBS LMs / RS4 Front Bumper / Hagus Mirrors / Brembo BBK / RS4 Shift Knob / JL Audio Speakers, Subwoofer & Amplifier / Clarion NX409 / HR Race Springs / Evolution Racewerks FMIC
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    It was only 95+shipping.
    But, i got em fixed. Working 100% now, it was probably just tension on one of the connections maybe.
    AND, i blame the sticky pad that came with the ballasts. it didnt hold like it should have.
    __________________
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    x2....the sticky pad sucks....I've gotta find a better way to secure mine cuz they've fallen off after only 2 weeks.....this is a great kit tho. Not like the other typical cheap HID kits (i don't know how some can knock a product they haven't tried themselves.....) Well worth the money. Good to hear u got it working
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Quote Originally Posted by JumboBlack1.8 View Post
    i used some silicon sealant and just glued it in with it ha
    __________________
    Aug 22 2008
    Central Maryland
    DDM 55w HIDs are now $40 + shipping. I am only in this thread because DDM are good people doing an amazing service to the euro community. For too long have vendors been price gouging us.
    Sep 16 2006
    '98 528i
    ^^ link? Thats unreal....I paid $85shipped I think
    Aug 22 2008
    Central Maryland
    DDMtuning.com
    They give away free HIDs with every BMW E36 headlight housing purchase..
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    UPDATE: Problem occurred again! going to contact ddm tommorow!
    __________________
    Senior Member Three Rings TheWrightAudi.'s Avatar
    Aug 07 2008
    White Rock
    wait i have that same problem. i have my HIDs set as my day time running lights. so there allways on. anyhoo when i start my car the light ''wants to start'' but doesnt fire up right away. so i found that if you set your light switch to full (two clicks up) it somehow ''juices'' the ballast and then it starts up no problem.
    its weird i no, and i probley have a faulty ballast considering it only happens to my passanger side, but i just learned to deal with it. made it work.
    1999.5,1.8T,5speed,quattro.
    Understeer -is when you go off the road and see the tree that kills you
    Oversteer-is when you go off the road backwards and dont see the tree that kills you
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    It's the bulb man. Did you even try swapping them to check?
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Quote Originally Posted by TheWrightAudi. View Post
    I thought DRL's get a lower voltage so they don't light up all the way(dimmer)? That would explain why it fires right up when you turn the actual lights on. If that is why you are having the problem you are having, you are probably doing a lot of hurt to your ballast/bulbs.
    Aug 07 2008
    White Rock
    Quote Originally Posted by Stampy View Post
    no they flicker on and off when first started. then once i turn on the light switch it somehow juices it to fire up strong.
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    because its getting the proper voltage to fire up the ballast....
    Aug 22 2008
    Central Maryland
    if its a defective product Jim will definitely take care of you. he always puts the customer first.
    Aug 07 2008
    White Rock
    ahh i c what your saying to it amps up the voltage. so its not really a bad thing then?
    sorry not my thread, but was curious to find out why that was.
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    From WIKI....
    "Canada
    Canada Motor Vehicle Safety Standard 108 requires DRLs on all new vehicles made or imported after January 1, 1990. Canada's proposed DRL regulation was essentially similar to regulations in place in Scandinavia, with an axial luminous intensity limit of 1,500 candela, but automakers objected, claiming it was too expensive to add a new front lighting device, and would increase warranty costs (by dint of increased bulb replacements) to run the low beams. After a pitched regulatory battle, the standard was rewritten to permit the use of reduced-voltage high beam headlamps producing up to 7,000 axial candela, as well as permitting any light color from white to amber or selective yellow. These changes to the regulation permitted automakers to implement a less-costly DRL, such as by connecting the high beam filaments in series to supply each filament with half its rated voltage, or by burning the front turn signals full time (except when actually flashing as turn indicators)."
    or read it here...
    http://en.wikipedia.org/wiki/Daytime_running_lamp
    Aug 07 2008
    White Rock
    that would make sense why they call them ''low beams''
    Apr 25 2007
    millersville, maryland
    different idea completely ...
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    DDM sells a wiring harness you are supposed to use for the problem you are having. The factory wiring isn't able to carry the amperage for 55w.
    HID Accessory HarnessUse this relay harness to connect HIDs to cars with very small gauge wiring that cannot supply the initial surge current required to light the bulbs reliably. Symptoms indicating the harness is required would be intermittant starting or lights going out after being turned on for several minutes and requiring you to turn the lights off and back on for them to turn back on again.
    Recommended for all 50W HID installations but most American and European cars work at 35W/50W without the harness. The harness is definitly recommended for Quad's and other ATVs or when running multiple HID installtions. This harness is a fused relay isolation harness capable of supplying 40A at 12vdc.
    Notice they say most European car work at 35 or 50 watts......not 55 watts.
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    im havin the same problem too. the passenger side *sometimes* doesnt fire up right away. ill just turn the lights off, then turn then back on once or twice and that tends to fix the problem.
    ThorTechnik.com
    Jul 30 2008
    08 Passat 2.0t
    Near Mountain Creek
    Quote Originally Posted by Toyotatech View Post
    All it is--- is a relay kit. YOu're relaying the ballasts with minimize wire length (increased length = more resistance). This is needed to ensure full power to the ballasts, especially when the HIDs are DRLs, as HID DRLs are at 100% intensity
    OEM HIDs uses the same thin wiring as non-HID, with the lighting relay in the same spot.
    08 Passat wagon 2.0T 6MT (APR Stage I, DriverGear-Eibach springs, Bilstein Sport, Euro smoked tails, intake, ATE Premium One rotors, Hawk HPS, Tyrolsport Caliper Guide Bushings, other stuff)
    Previous Cars:
    02 Golf TDI 5MT (Chipped, Bosio PP764 nozzles, VNT-17, Shine Racing suspension, S3 strut brace, WRD rear strut brace)
    88.5 Camry V6 5MT
    84 Corolla 3AT (the FWD version, hand-me-down)
    Dec 05 2007
    I do not know about the issue withy the bulb not igniting. But as for where to mount the ballasts, use 3mm double sided sticky tape. Another thing one might want to try is to increase amperage on the low beam fuses, given that the wirings are all correct. But it really should not make a difference as the stock low beams are 55w and the HID is 55w. Unless it may take a little more wattage for them to ignite. Here are pics of where I mounted my ballasts (Retro-Solution):
    Driver's side (next to ABS module/power steering fluid resevoir)
    Passenger's side (held on by double sided sticky tape upside down under the plastic peice that molds the designatd headlight housing)
    *side note: double sided sticky tape is some powerfull sh*t
    edit: I am on a laptop currently as my desktop is at a place getting all the bugs fished out. If the pics do not show up, here are the links (Driver's side/Passenger's side)
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    But wouldnt the fuse blow if it was inadequate?
    I'm just surprised how common the problem i am having is with the DDM hids.
    Why should i have to buy a relay kit for something to work?
    Oh yeah seerlah, those pics didnt come up for me!
    __________________
    Dec 05 2007
    The pics should be up now, and I also added photobucket links. As long as the wires are rated to handle the added amperage then you will be fine. There are many people whom up the aperage on thier fuses when they run into complications such as so. Just add 5 more watts and see what happens, after you take Stampy's advice. The thing is you can add higher amperage fuses (taking into consideration that the gauge can handle it. in this case, I am almost posotive it can), it is just never a prudent thing to lower the amperage. That is when you start to blow fuses.
