    Mar 18 2007
    Ottawa Ontario Canada
    Can brake fluid leak onto an exhaust component?
    Hi guys,
    I searched and search but I couldn't find an answer. Here is what's happening.
    - Drive and all is fine BUT
    - if I brake hard I'll start to smell something burning
    - the smell is definitely coming through the vents
    - It almost smells like burn oil but it is missing something which leads me to believe it's brake fluid
    - After I take off again, the smell eventually goes away.
    -Now the (0) light is flashing three times along with the beep which seems to mean that I need more brake fluid.
    This has me thinking there's a leak somewhere in the brake system which is causing brake fluid to leak onto a part of the exhaust. Has anyone ever experienced this and if it is brake fluid, would anyone know where this leak may be occurring???
    P. S. I know what burn oil smells like (had a leaky valve cover for awhile until it was fixed) and I don't think it's oil, close though.... I'm just putting two and two together. 1. Weird burning smell and 2. low brake fluid a few weeks later.
    Can someone PLEASE Help
    Jun 08 2008
    Calgary AB Canada
    Re: Can brake fluid leak onto an exhaust component?
    wouldnt a brake fluid leak lead to your brakes not functioning properly?
    do you have a spongy pedal? and signs of brakes failing?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Check your front calipers for signs of leaking. you may have a leaky piston seal. When you hit the brakes hard the brake fluid could be leaking and getting on the rotors. Thus the burning smell.
    Mar 18 2007
    No signs of brakes failing but the faulty seal sounds like a strong possibility. I'll check it. Just to add, there are no leaks on my driveway so whatever it is, it's minor. I just hope the repair bill isn't if I have to take it to a garage.
    I'd love to hear more opinions if anyone else has experienced the same issue.
    Chers and Thanks :)
    Senior Member Three Rings kastro's Avatar
    Mar 20 2008
    04.5 1.8TQ Tip A4 Black -
    Ottawa, Ontario
    what part of ottawa u located man..
