Results 1 to 18 of 18
Thread: no heat
    Senior Member Three Rings 102487thedude's Avatar
    Apr 06 2007
    BMW M3, X5 50, A4 BT
    Cresskill new jersey
    no heat
    My car is getting up to temp but I have know heat coming out of my vents. Any ideas welcome
    2.0 stroker, built aeb head, T3/TO4E t-61 BB F162 .63AR turbonetics turbo, front mount, open down pipe. Port and polished intake manifold. 800cc injectors.
    and a our New cayane GTS in red.
    visit,
    http://quicktimeperformance.com/
    http://www.theshopct.com/
    Oct 09 2008
    1999 Audi A4 2.8 Quattro
    Hartford CT
    Re: no heat
    check your heater core
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Re: no heat
    First find the supply and return lines going through the firewall to the heater core. If one is hot and the other is cold the problem may be a clogged heater core. If neither are hot you probably have some air in the system. Slowly open the bleeder valve on the hard line running parallel to the fuel rail and as soon as coolant starts to flow out close it.
    Veteran Member Four Rings BlackB6's Avatar
    Apr 03 2008
    Pennsylvania
    Re: no heat
    Heater core.
    Apr 06 2007
    Re: no heat
    where is the heater core
    visit,
    Dec 06 2007
    Re: no heat
    ^^listen to old guy
    -Kirk
    BetaAlphaTau Member #58
    Dec 28 2006
    Western Maryland
    Re: no heat
    Quote Originally Posted by 102487thedude View Post
    The heater core is under the dash. The lines you see in the pic are down around your right foot. If you find that you have one hot and one cold supply line I would recommend reverse flushing the heater core by running a pressure hose in the cold line and out the hot line. both will need to be disconnected from the block when you do this. Quite messy but less work than replacing the core if it works. (Thanks to JJ for the pic!)
    Good luck!
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    Re: no heat
    hmm my dads old chrysler has the same problem...
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Feb 05 2008
    Waterloo NY
    Re: no heat
    when the car is idleing it has heat at low blow, but if you turn up the blower it seams to be colder air, and there is almost no heat while driving
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    C5 allroad 2.7 auto
    Apr 06 2007
    Re: no heat
    is there a pic or can some one tell me wherei can find those lines in the engine bay and where i should undew the lines. also can i use a air pressure to clear it out?
    visit,
    Dec 28 2006
    Western Maryland
    Re: no heat
    They both go through the firewall at the back of the motor slightly toward the drivers side of the firewall. They are hard to get to, but fortunately can be disconnected by pulling out the wire retaining clip that holds them in place to the hard lines coming off the motor. One connects at the center rear of the block. The other connects below the back edge of the intake manifold. Once you find that one you can follow it down to where it goes through the firewall. The other line goes through the wall right beside of it. Unfortunately because of their location the job is fairly arduous.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: no heat
    Do this first Blake!
    -Doug
    Apr 06 2007
    Re: no heat
    it was air in the lines. thanks for your help everyone. Old Guy, you saved me lots of money hanks again.
    visit,
    Dec 28 2006
    Western Maryland
    Re: no heat
    glad to hear you got it working!! How's the repairs on the C230k going?
    Apr 06 2007
    Re: no heat
    it was the lower swing arm and as soon as a put a torch up to the joint it poped right out using my ball joint remover and then i went for a test drive and everything is good now. thanks again.
    visit,
    Dec 28 2006
    Western Maryland
    Re: no heat
    Good deal!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: no heat
    good deal! glad to hear both cars are squared up.
    -Doug
    Apr 06 2007
    Re: no heat
    you and me both. final coast only about $200 including parts and tools and fluids. original coast for ne heater powerstearing pump and benz swing arm came to a total of 1100 so i save my self 900. and i am very happy.
    visit,
