Results 1 to 8 of 8
    Veteran Member Three Rings jankaroni's Avatar
    Mar 01 2007
    Emerson/NJ/USA
    drive axle nightmares...
    [Begin rant/] So I am about to take a trip to NC about a 7 hour trip from me in NJ. I have my car on the lift at work and decide to look it over before the trip and everything is good....except my outer CV joint boot is torn. No big deal right? I wish. My plan was come into work the next morning a lil early and pull it out and send it out to get a new boot put on for 25 bucks. I don't know if it was just my luck, but that main axle bolt wouldn't come out for its life, I had a 260lb guy with a 4 foot breaker bar on it and it was laughing at him. Save your self the trouble and just buy a new bearing and a new axle (since they are extremely cheap) and take a torch and heat the piss out of the main bolt and it will come back off, it will save you about an hour of messing with the bolt and trying to get it out because it is pretty much impossible otherwise. All in all it worked out for me in the long run because I got a rebuilt axle for 62 bucks and a new bearing for 120, however, me and the 2 mechanics that were trying to help me out said that was by far, the WORST axle to get out they had ever seen. [End Rant/]
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Re: drive axle nightmares...
    That's odd - I take it you're referring to the central bolt in the hub?
    Seeing as the threads are in constant contact with the thick grease the axle joints are filled with, I'd have thought they'd be easy to undo.
    I've never had an axle bolt fail to come undone. On earlier B2/B3/B4 cars, yes. But these have a nut, rather than a bolt, and the exposed threads on the nose of the axle joint tends to get rusty.
    You must have just been unlucky, and had the misfortune to wrestle with a B5 that bit back.
    Mar 01 2007
    Emerson/NJ/USA
    mine didn't have a nut, mine had a a bolt that was about 4 inches long with a big allen key head on it
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    use some penetrating oil and more leverage. mine took a little bit put it came out when i got a long cheater bar
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Mar 01 2007
    Emerson/NJ/USA
    haha, i had penetrating oil on it and actually put penetrating oil on it and let it sit for like 2 hours, and ass far as a longer bar goes....the one we had was 4 feet long. I will put it this way, we twisted off 4 allen key sockets before we got it out if that tells you anything haha as soon as we heated it up cherry red it came out with absolutely no effort, however the bad part of heating it up is you toast the inner bearing and have to replace it
    Apr 13 2008
    six zero seven, NY
    Quote Originally Posted by zrowcool View Post
    Agreed on that - use Deep Creep or something to that effect and let it penetrate for awhile. Maybe 2-3 applications over an hour's time and it should come right out.
    1999 A4 2.8qm (air intake, chrome depos, clear sidemarkers, smoked tails, paint-matched interior trim, slotted/drilled A8 BBK, hawk pads, AT Italia 17" wheels, full A/V system)
    Junior Member Two Rings
    Nov 17 2008
    Nokesville, VA
    That's funny; I've done countless cv boots using my 1/2" 30 some odd inch breaker bar to take the bolts out. Maybe your bolt was unusually rusty (or severely overtightened at one point).
    Mar 01 2007
    Emerson/NJ/USA
    Quote Originally Posted by Scrampa View Post
    That's what I was thinking too, it seemed like it was seized really because once it broke loose it came right out by hand. All in all it worked out in the long run for me I did a little better job with it due to the bolt not coming out without heat. Now I have a new drive axle and a new wheel bearing up there so its all good
