Results 1 to 2 of 2
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    changed my plugs yesterday, question about what i saw
    hey guys, i changed my plugs yesterday (ps, bosch isnt making the f6dtc anymore, they switched to the fr6dc, we shall see how they work out.)
    anyway, cylinders 1, 2, and 3 had the usual little bit of oil on the plugs, which were somewhat loose. cylinder 4 had no wet oil on the plug, only a dried brown substance, i assume oil. the best way to describe it i guess would be to say that it looked like dried coffee.
    so, experts, what is the deal with this 4th cylinder? no misfires, no visible, significant, or consistent lose in power or boost, no codes, etc.
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: changed my plugs yesterday, question about what i saw
    brown is ok... white = lean and black = rich so you are good. Oil is probably just a leaky spark plug gasket under the valve cover. No worries. It's a quick fix.
