Results 1 to 23 of 23
    May 26 2008
    C63s AMG
    Boston
    S6 LED wired to foglight
    I just got my car back (actually it's my GF's) from body shop after the retrofit of S6 LED to the S-line bumper.
    They did an awsome job on modifying the foglight housing to make it look flush!!
    But I think they kind of messed up with the wiring cause it only turns on when foglight switch is pulled with the headlight on.
    I wanted it to be on with parking light on as well.
    Does anyone know why it doesn't work when I pull the foglight switch with parking light on?
    (pics to follow tomorrow afternoon)
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    Re: S6 LED wired to foglight
    Quote Originally Posted by lyjw88 View Post
    because the fog lights don't turn on when you turn your parking lights on either, even if you pull for them.
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    May 26 2008
    C63s AMG
    Boston
    Quote Originally Posted by Charlescrs6 View Post
    Uhh..is it?
    I thought it used to work with OEM foglights.
    I know it's a different story but I get to turn them on with parking lights on my bimmer.
    Veteran Member Four Rings got boost.'s Avatar
    Jun 03 2007
    california
    you can tell them to rewire the LEDs to the parking lights so when you turn the parking lights on and they will be on.
    l BBS l FORGE l STERN l VMR l ER l SPEEDTUNE l
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    by parking lights you mean the turn signals? or the little city lights?There is a mod on here that shows you how to do it with the city lights. which are on with the turn signals but you can vag those off.
    The usual things!!
    Resistor Install
    Jun 03 2007
    california
    yes parking lights as in turn signals.
    Feb 16 2008
    Oakdale, MN
    http://audizine.com/forum/showthread.php?t=188467
    This should solve your problems
    The usual things!!
    Resistor Install
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    or you can just VAG it to Canada mode. and the will be on as daytime running lights and when you turn on your headlights they will cut off the you pull it to turn it back on.
    BTW how did they wire them up because i want to do the same with my b6 and im trying to gather some info for a DIY.
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    May 26 2008
    C63s AMG
    Boston
    I finally figured how to turn the fogs on with the parking lights on (thank you for providing the link above)
    Here are some pics of the product as I promised, sorry for the crappy white balance which made the LED look yellowish.
    May 26 2008
    C63s AMG
    Boston
    Quote Originally Posted by yung turbo View Post
    I have no idea about the wiring.
    The body shop did it for me..
    Jun 02 2008
    Fort Collins,Co(college)
    I love the s6 LEDs!!! I want to get a body shop to install some on mine as well. If you don't mind me asking what did the body shop charge you? I'm trying to get a figure in my head of how much I'll be spending.
    Veteran Member Four Rings whitevdub's Avatar
    May 10 2007
    Long island
    looks great...nice and clean
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    love it!
    Senior Member Three Rings fromGMCtoAUDI's Avatar
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    Looks very good!
    Quote Originally Posted by wcoltharp View Post
    X2
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    personally i would set additional lights like that to another separate switch just so you can turn them off and on with your command regardless of what other lights are on. This pretty easy to do if you want to take it to an car r
    May 26 2008
    C63s AMG
    Boston
    thanks for the compliments.
    and check your PM Wcoltharp.
    Mar 09 2005
    Santa Clara, CA
    Quote Originally Posted by Sanjman View Post
    that's what i ended up doing
    Feb 19 2008
    NYC/DE
    can you pm me the price you paid as well.
    TuRboK1ng
    Veteran Member Four Rings slimmj0k3r's Avatar
    Jul 31 2005
    Arizona
    mine act as DRL's (thats what they are on the S6) but they stay on even with the lo-beams, eventually i'm gonna wire them up to a switch that i can flip on/off
    May 10 2007
    Long island
    sorry to bring this thread back but i was wondering if they had to modify the bumper or just the fog light housings? interested in possibly doing this this summer
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    can you post a close up of where the outside of the LED's go into the bumper..i want to see how they made it fit.
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Jul 31 2005
    Arizona
    Quote Originally Posted by whitevdub View Post
    you need to cut into the bumper..
    Feb 01 2008
    Miami
    With mine its wired through an auxillary fuse so it goes on with the key and you dont need to bother with using the light switch....so mine are on all the time like the real S6 lights
    || Britalman Quad tip || Custom Britalman downpipe || H&RCoilovers|| 19" HRE 540R || Hardwired Valetine One || Two tone Alcantara seats|| Podi Boost gauge||
    ||DTM front/Rear||S6 LEDS||VR6 12V Precision GTS 76 w/ 6spd swap 427AWHP low boost tune for now||
