Results 1 to 4 of 4
    Nov 21 2008
    OH
    A6 Acceleration Hesitation
    2001 A6 2.7T 60K:
    From stop position, acceleration is hesitant, and flat. Problem is sporadic, probably 50% of the time. Otherwise it seems normal. Temperature seems to make no difference. It takes pumping, or jogging the pedal to make it kick in. Problem has been evident for over a year or so, and the check engine light has appeared, but only recently. Mechanic said that the engine light code was a Catalytic Convertor pre-heater. Are the two related, or only coincidental, otherwise any thoughts on the hesitation issue?
    The car wouldn't misbehave when in the presence of the mechanic.
    Thanks
    Senior Member Two Rings mpower's Avatar
    Feb 02 2008
    01.5 Nogaro B5S4, 2012 B8S4 Glacier Prestige, 09 Q7 S-line TDI
    Chicago
    Re: A6 Acceleration Hesitation
    Could be anything from a faulty O2 sensor to a boost leak. Scan for codes with VAG-COM or OBD2 reader at Autozone and post back.
    Nov 21 2008
    OH
    Thanks for the advice.
    Senior Member Two Rings African2.7T's Avatar
    Dec 18 2007
    B5 S4 Laser RED
    PA
    Do you let the engine adequately warm that could be your problem
    MK4 GLI Blue lagoon
    B5 S4 Laser RED
    Past Rides
    C5 A6 2.7T
    B5 S4 Santorin Blue
    MK4 JTI VR6 Money Green..lol
