Results 1 to 19 of 19
    Registered Member Two Rings xxForgedxx's Avatar
    Aug 22 2008
    PA/ME
    If you have had a major issue ($1,500+) with your S4. POST
    If you have had an issue that cost $1,500 or more dollars to fix/replace/repair post here. If you have a warranty, how much WOULD it have cost?
    Year of your S4:
    What was the issue?:
    Why did it happen?:
    What mileage did it happen at?:
    Did it happen again?:
    Forge1 [fawrj, fohrj] to form by heating and hammering; beat into shape.
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    Re: If you have had a major issue ($1,500+) with your S4. POST
    Ac unit quit working - cold as hell one day, hot the next. Dealer replaced compressor, dryer etc etc all under CPO warranty. Would have been over $1500, but covered under CPO warranty.
    Clutch... Around $3000 at dealer, paid much less elsewhere.
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Sep 19 2007
    seattle
    2008
    problem 1:Oxygen Sensor
    problem 2:Oxygen sensor again but dealer said it was ECM..so they changed it.
    Both happened within first 1500 miles and it's problem free since then
    Yes, covered under warranty
    Jan 10 2007
    Earth
    Quote Originally Posted by cellg8 View Post
    2008
    FYI, an oxygen sensor cost under $400...
    2013 White 911 4S
    2005 Moro Blue S4
    Sep 16 2008
    B6 S4 Avant Nogaro 6-speed MT
    Normal, IL
    Before I owned the car. Previous owner gave me service records....
    Clutch replaced: 53,934 - 1/19/2007
    Transmission 2nd gear & synchronizer replaced: 64,793 - 8/13/2007
    I think the clutch was around $2700 at a dealership and may have been covered under an extended warranty. The 2nd gear and synchro was around $5500. I think he paid for that. I would have to go back and dig through the records, but I think those are the amounts paid IIRC.
    Aug 22 2008
    PA/ME
    Quote Originally Posted by Captain Insano View Post
    My god, a 2nd gear syncro fix was almost $6,000?! That's fucking madness!
    Sep 16 2008
    Normal, IL
    Wasn't me man. LOL... But yeah, definitely some lunacy there. I bet you could get that 2nd gear fixed cheaper than $5500. He had it done at a dealership though....
    I cringe thinking about how bad a shifter he was most likely. But at least my clutch and trans should be in decent shape now (I hope - knock on wood).
    Aug 22 2008
    PA/ME
    I refuse to pay that kind of money to maintain a car that isn't even that high performance. $5,500 for the entire TRANSMISSION?! ok, but a fucken SYNCRO repair? Umm no.
    Sep 16 2008
    Normal, IL
    It actually said the second gear and the synchro were both replaced. Not saying that warrants $5500. Just stating what I read on the service record.
    This happened in CT apparently. When I asked, I had a local service guy here tell me it was probably so expensive because you cannot replace a single gear and you have to replace the entire transmission.... But that sounds kinda wacky to me and I dismissed that as BS.
    Jan 10 2007
    Earth
    Seems like the dealership taking advantage of a rich guy. I bet the car was under 2 yrs old at time?
    2013 White 911 4S
    2005 Moro Blue S4
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    what'd you expect! not an A4 anymore....it's a $60,000 car.
    Quote Originally Posted by xxForgedxx View Post
    Veteran Member Three Rings poopypants's Avatar
    Jun 18 2007
    '64 LeMans, '00 CBR929RR
    Perris, CA
    Quote Originally Posted by ieatfishburitos View Post
    oh really? What were your symptons? Every few days it gets hot, my a/c doesn't want to run. The next day it works fine. I take it to the dealership and they say im using the a/c wrong. The service rep tells me i have to use the "auto" button first. Stupid b!tch.
    Sounds like the original owner was beating up on the transmission. Synchros just don't crack for the hell of it. That and second gear, yeah... i know from experience.
    "The Constitution of most of our states (and of the United States) assert that all power is inherent in the people; that they may exercise it by themselves; that it is their right and duty to be at all times armed."
    - Thomas Jefferson
    Aug 22 2008
    PA/ME
    Quote Originally Posted by poopypants View Post
    $5500 is still a super rip off
    Sep 16 2008
    Normal, IL
    I think if I recall the records correctly the orignal owner bought it in 6/2004 and it was manufactured in 4/2004. So it was just over three years old at the time of that trans work. And he had owned it just over three years. Is drive train warranty only for 3 years or 4 years on the 2004 S4s? I thought mileage warranty was 40,000 or 50,000. If 3 years he paid cash money green for that work and it wasn't warrantied I would assume. Not sure if some or all of it was warrantied because I don't know the guy.
    I agree - he was most likely beating on it or doesn't know how to shift - or it was a magical combination of both attributes.... The aftermarket folks I've asked have said this transmission is pretty decent. Not bulletproof, but decent so the original owner was doing something wrong is my bet.
    Veteran Member Three Rings szinkuti's Avatar
    Oct 06 2008
    Allroad Truck aka Uber UTE
    Grand Prairie, Texas
    gears and synchros can be replaced...pretty common actually...and 5500...eh...seems kinda high even for a dealer.....and the s4 trans is cake to tear down and repair....
    Nov 15 2008
    2005 S4 6spd, Suzuki B-KING
    Chicago Burbs
    got lucky this week, just bought the s4 last week used with 38k. was driving to work tuesday, car cut out on power, and cel was flashing hardcore. Called audi, they said tow it over dont drive it. Had it for three days, ended up being a blow cat. Tech said it would have been 2k+ had I not had warranty left. Said it was the first time he ever seen a cat fry up to pieces.
    Don-
    Light Silver/Blk 2005 B6 S4 Six spd every option - Carbon Fiber - LM25's on stockers - Ruger R10 19's - Falken 452's 235-35-19's - Milltek Non Res CB-Magnaflow 14851's Mufflers- X-Pipe - APR DP's - Rs4 Pedals - JHM SSK - Flapper mod - WAITING on JHM LT's
    Sep 16 2008
    Normal, IL
    I would have them go over the car with a fine toothed comb. Are there any modifications on the car? That could be a symptom of another problem (very high EGTs most likely or running super rich or a combo of both at different points in the powerband). And there could be some other major things that caused your cat to go that early....
    Veteran Member Three Rings Jdubya's Avatar
    Apr 05 2006
    05 S4
    Dayton Ohio
    Getting ready to drop $1800 on clutch/flywheel with install.
    FI DP | FI CB | JHM IM | JHM TUNE | JHM N20 | SB STAGE III/LWFW | PORSCHE BBK | BBS CH | KONI/H&R
    Nov 15 2008
    Chicago Burbs
    Ya they went over the whole car for a few days they couldnt figure it out. They said everything else checks out great, said my motors real strong. My car has no mods at all which is the weird part. The tech said hes never seen a cat go.
    Don-
    Don-
