Results 1 to 9 of 9
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    Review of Blizzak LM25's
    So finnaly got around to having my new bridgeston blizzak LM25 mounted on some 17" S4 avus rims. Did 80 miles today, about a 60/40 highway to city split.
    First thing I noticed was that the car seems to be working harder to get up to speed.
    Second thing was that according to the computer my MPG dropped by about 2-3 mpg.
    I know these are strictly winter tires and I have them just because I go to the mountains a lot and I have a little cottage in maine that is always burried in snow, so that is where I'm expecting these to shine.
    In retrospect, because I commute 60+ miles a day, maybe I should have gone with something not as extreme?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: Review of Blizzak LM25's
    If I recall correctly, the LM25s are a longer lasting winter tire. Therefore the compound would not be as soft as the other Blizzak models.
    I have over 20k on my LM25s and they are hardly worn. The only difference I notice on the road is more body roll since my 17inch LM25s have more sidewall than my 18inch summer wheels.
    -Doug
    Mar 20 2006
    Have you noticed anything as far as acceleration goes?
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    ^^ probably not with his setup.
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    If the rolling diameter of the LM25's are greater than the wheel you usually use, then that will TECHNICALLY contribute to the slower acceleration speed. Even so, it might just be your mind
    -Sami-
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by KPC1.8TQuat View Post
    Nope.
    The outside diameter of my 17inch tires and my 18inch tires is exactly the same.
    -Doug
    Veteran Member Three Rings dewey527's Avatar
    Mar 10 2008
    '02 a4 1.8tq, '05 tahoe
    Puyallup
    i have the michelin alpin on 215/55/16 and i corner like a vanagon but boy do they grab the snow. haven't paid too much attention to mileage.
    mods - not enough for me and way too many in my wife's opinion
    K04, Revo "Stg2", PODI Boost Gauge, TT225, fmic, Forge DV, Tantrumwerks 300cell HFC, Neuspeed Exhaust, Stasis Touring Suspension, Spec Stg2 & LWFW, 034 RSB, Neuspeed SS, Neuspeed Snub, Neuspeed TIP, B6S4 front brakes, Tyrolsport Kit, 6K HID, Yellow Fogs, 20%, CC
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    The compound is softer so you'll notice a drop from strict summer tyres.
    The LM-25s are a good bet but I've personally found the Dunlop WS 3Ds to be better. Again, that's just a personal choice. In my opinion, you're not giving up much.
    You'll notice the better grip as temps plunge and especially in the deep snow and slush. It should outweigh the softer sidewall feel and earlier give tendency of winters on dry vs. summers on ice.
    Good choice and good luck!
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Mar 27 2005
    The Cold North
    you are fine commuting on the LM25's. I just put my snow setup on and i also notice the same things as you. For my setup it is due to the increased weight over my summer setup. My winter wheels (18") + runflat tires are about 11#'s more per corner than my summer setup. Also the softer compound of the winter tires doesn't help either. Oh well. I am more than willing to sacrifice a couple mpg's and handling for a few months to have the better control when stopping or accellerating in the winter snowy conditions. Better safe than sorry.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
