Results 1 to 19 of 19
    Veteran Member Three Rings drexplode's Avatar
    Jul 19 2007
    2016 M3 - maximum hooligan
    Michigan
    WTF is going on?
    I come home today and turn off the B5 2.8, about 5-10s later I hear what sounds like a vacuum cleaner running on the passenger side of the engine. Every so often the vacuum turns on and then off...
    cooling fans are definitely not spinning
    does the 2.8 have an electric water pump? If so, i'm not sure why it would turn on...car wasnt even at max operating temp. Ambient temp is like 27/28F. What is this noise i am hearing?
    "A turbo boost gauge the size of a fat spaniels face! - Jeremy Clarkson
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    Re: WTF is going on?
    Secondary air injection pump maybe.
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Veteran Member Three Rings a4937's Avatar
    Aug 14 2008
    Ohio%20
    Quote Originally Posted by yung turbo View Post
    That would definitely be my guess, but mine "runs" only when the car is running. You can bypass it but it's not a cheap job, my mechanic told me that the thing could go out completely and the car would still run perfectly. If you have a CEL that is probably the cause.
    Jul 19 2007
    Michigan
    Thats what my mechanic said too...but why in the hell would it be running when the car is off?
    I just disconnected the battery to avoid a dead battery in the morning...
    Are they easy to replace?
    I have a CEL anyway because of an exhaust issue, but not a biggy... but i dont have a reader so im not sure if there a CEL for this problem.
    Veteran Member Four Rings the_pirate's Avatar
    Apr 08 2008
    Houston
    it stays running or it shuts off after a couple seconds?
    History:
    2001 A4 1.8t manual swapped
    2007 GMC Sierra ext cab
    2002 Chevy Tahoe Z71
    Jul 19 2007
    Michigan
    when i got home it stayed on for a probably 60-90s, shut-off, then intermittently turn on for a few seconds (5-10) and then turn-off... the intermittent on/off happened 5-10X more. Finally, I just yanked the -neg terminal on the battery.
    Aug 14 2008
    Ohio%20
    Quote Originally Posted by drexplode View Post
    Mine will run for about 20 seconds when I first turn the car on then go off.. and sometimes run when sitting idle at a stop sign or red light.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    SAI
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Apr 08 2008
    Houston
    Quote Originally Posted by a4937 View Post
    thats normal.
    drexplode sounds like the secondary air pump is dying....
    History:
    Jul 19 2007
    Michigan
    bah, SOB. A coolant leak 2-3 weeks ago, and now another problem... B5 is just checking to see if i still love her. After buying Adam's B5-S4, she knows...
    DIY for SAI?
    Damn, $300?? http://www.autohausaz.com/search/pro...20@Smog%20Pump
    Edit: p/n 078-906-601-M is 230 shipped from genuinevwaudiparts.com
    any risk of damaging other components while driving around with the problem? since it runs after key-off then I should probably disconnect the battery everytime to avoid killing it.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    remove it for now. you don't need it.
    and if you have emissions, then just make sure you get it back in there by inspection time..
    or if you don't have emissions. leave it out
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Jul 19 2007
    Michigan
    Quote Originally Posted by sean1.8t View Post
    thanks Sean. any DIY or pictures you know of to remove it? Or maybe a fuse i can pull to avoid draining the battery? no emissions in MI.
    Jul 19 2007
    Michigan
    haha i just re-connected my battery and immediately the SAI pump started to whine... this is the m-fer making the noise:
    Jul 19 2007
    Michigan
    final conclusion: unplugged the bitch.
    on a positive note, i vacuumed behind my fridge since it was out while i looked for my LED mini-light.
    Aug 14 2008
    Ohio%20
    How did you unplug it? Are those pics from under the car?
    Apr 25 2007
    millersville, maryland
    There's actually a plug facing the front of the car right on the front of the SAI. Mine was kind of a b!tch to get off because of road grime. I eventually just took the pump and hoses out.
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    weird, i thought there was no SAI on 99's.... mine definitely does not have it
    {99.5 Avant}
    Jul 19 2007
    Michigan
    yeah those pics are from underneath the car on the passenger side near the front wheel. Soon as you drop the belly pan it is sitting right there next to the oil pan. The e-connector is facing the front of the vehicle, with age and road grime I snapped the locking tab off. Afterwards, cut up 1 of my best buy rewards mini card in the shape of a rectangle and cover the end and wrapped the mofo w/ 8lbs of electrical tape. Once i find that money tree I will shake it for $230 and replace the SAI. For now, i will live without. However, i still have no idea how to remove it...i tried last night in my 25F garage and gave up when i couldnt feel my toes or fingers.
    picture of a new one at ECS tuning:
    Established Member Two Rings okar's Avatar
    Sep 26 2008
    2.8, '63 beetle,66LandRoverIIA
    seattle
    The rusty nuts shwn in photo are holding it in housing that it sits in. I am rebuilding a crushed front end 2.8 and i was wondering what that was...
