Results 1 to 14 of 14
    Dec 31 2006
    boston, ma
    Bad motor mounts: did you feel this?
    trying to diagnose something that has been bothering me for a long time..a shifting and clunking feeling when going over bumps...my control arms have checked out good, as well as tie rods...so i think its my motor mounts but i dont see anything leaking...so...while idling and my clutch depressed, i rev the engine a little bit and feel a clunk...motor mounts?
    2010 A5 Brilliant Black, 6 speed
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Re: Bad motor mounts: did you feel this?
    possibly motor mounts, also check your CV joints, and tranny mount.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Dec 31 2006
    boston, ma
    Quote Originally Posted by Audi Skate Snow View Post
    not sure cv joints would clunk while at idle...this is also a feeling, not a noise
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    same issue here, i thought my snub mount was causing it, but i changed to apikol and still same sound when i shift gears fast. i saw a sale for all mounts going on not too long ago, does anybody know if its still going?
    Mar 31 2004
    CA
    Quote Originally Posted by eclimax13 View Post
    shoot didnt read that part... sorry.
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    My steering wheel is shaking when i'm at idle, sometimes it shakes pretty bad + some weird noise. dont even know what is that.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Oct 08 2007
    Columbus, OH
    Quote Originally Posted by aaaudiprotein View Post
    mine does too, especially after few drinks, but even worse if i had a bottle of vodka. usually stops around noon of the next day
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    lol
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    Thats what I felt after my passenger side mount was gone. It was very hard to shift smooth from 1st to 2nd and letting off the throttle in any gear would give me that thump feeling. I do not rev my motor much at idle, but I'm sure it would of felt the same.
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    Quote Originally Posted by J-jizzle View Post
    WOW mine does that... what did yours end up being? I should check my mounts too.
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    As with most things that don't break, but progressively go bad...you may not really notice your mounts are bad because you get used to the feeling of drivign with bad mounts.
    I noticed mine were bad when I saw fluid all over my Pass side one at about 57K miles( no fluid leaking from my Driver's side, but it had just about as much play as my visually bad passenger one). I replaced my snub at about 50K as it was cracked/very worn w/ a Stern from PureMS. I'm pretty sure my mounts were going out then and just put extra stress on the rest of the system.
    I was having exhaust issues at the time and had my flex-pipe replaced (welded in a new one) which caused my exhaust to sit a little closer to the subframe. I started noticing my exhaust rubbing/rattling on the subframe when I'd rev the engine or turn sharply.
    I installed 2.7T S4 Mounts and after noticed shifting was alot smoother (especially the 1-2 shift and had alot less issues when shifting into 2 from 1 or 3, cold or warmed up) and overall the car felt alot more solid (only way I can describe it). It was as if the shifting, steering and handling was less sloppy.
    Aug 28 2007
    Quote Originally Posted by Charlescrs6 View Post
    Both mounts had there fluid leaked out and the mount under the exhaust manifold was tore 65% the way around.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    i had both of mine go out, and i too had s4 mounts put in (at the stealership actually had a new younger service rep), and i too thought it was the snub and upgraded to the stern unit. my idle was really smooth when they were out but shifting 1-2 and/or letting off the gas in 1 or 2 would cause a bad jerk. i thought it was my mbc and diode not running smooth but with the new mounts its really smooth, but idles really shaky esp. when cold.
    barrett
    2019 SQ5 Prestige
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    maybe tranny mounts?
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
