Results 1 to 40 of 51
    Veteran Member Four Rings eastwick897's Avatar
    Jun 26 2008
    New Jersey
    Got my car Dynoed today
    I'll have the dyno sheet up later tonight. The Dyno run was done on a MAHA dyno. but these were the numbers:
    276.9 hp- to the crank
    185 hp- wheels
    323.1 lbf.ft- of torque
    B7 A4.... 394awhp
    Veteran Member Four Rings Six Speed Turbo's Avatar
    Feb 09 2007
    Hopes, Dreams, Tools, Car Parts
    Killeen, TX
    Re: Got my car Dynoed today
    Nice numbers, what mods do you have?
    2016 S3 Prestige - Glacier White Metallic, APR Stage 3+, APR TCU upgrade, APR CAI, APR FMIC, APR Catchcan, APR Lowering Springs, P3 Guage
    YouTube Channel https://www.youtube.com/channel/UC88...LbgXXvRHPvW3Xw <---SUBSCRIBE
    Jun 26 2008
    New Jersey
    ^^basically all the bolt on things you can put on. AWE FMIC, TP, Milltek cat-back, fuel pump upgrade, water/meth, revo st2, forge DV, crank pulley, GSG intak pipe. I was running 7-8-9 settings on my best run which was this.
    B7 A4.... 394awhp
    Feb 09 2007
    Killeen, TX
    Wow I guess that type of dyno reads pretty low then. I have all the same mods except I have APR and no water/meth.
    Jun 26 2008
    New Jersey
    ^^^ Yea
    B7 A4.... 394awhp
    Veteran Member Four Rings AWDTURBO's Avatar
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    they have you at almost 33% loose at the wheels .. thats really odd ..
    Most cars loose 25-28 % if that
    Jun 26 2008
    New Jersey
    ^^^Quattro looses around 30% to the wheels though so 33% really isn't that off.
    B7 A4.... 394awhp
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    nooo .. quattro looses about 25%
    front wheel looses about 15-18%
    Jun 26 2008
    New Jersey
    I always heard 30 man... But hey it is what it is. I wasn't expecting anything high anyway.
    B7 A4.... 394awhp
    Registered Member Two Rings b7ftw's Avatar
    Aug 06 2008
    2005.5 B7 A4 2.0t 6MT
    Phoenix, AZ (Tukee)
    that is a huge power loss... are you sure that the 185 wheel hp is the top hp, not the hp at the top crank hp level?
    when i dynoed mine on a maha dyno it put stated that the max wheel hp was 185 which wasnt the case, it was 185 wheel hp when the max crank hp was reached... my max hp was just shy of 200 (194 if i remember correctly, not a huge difference, but still)
    GIAC-X 91 / EVOMS Intake / APR Exhaust / ATP Testpipe / AWE Intercooler / Stage 2 South Bend Clutch Kit / VMR 710 GM / Neuspeed Springs (coils soon) / Depo Projectors w. MTECs / Reiger roof wing / JPUSA rear lip / debadged / Tint
    Aug 06 2008
    Phoenix, AZ (Tukee)
    PS - my FWD drag power was measured at 57 HP (which i believe means that at max crank HP 57 HP is lossed through drivetrani, im sure someone will correct me tho)
    Jun 26 2008
    New Jersey
    ^^ I'll have a pic for you guys by 2morrow. Just to make sure I'm interpreting this thing out correctly.
    B7 A4.... 394awhp
    Veteran Member Four Rings Louis J.'s Avatar
    Dec 26 2007
    PNWR
    Drivetrain loss depends on the dyno. Some loose mid 20s while others loose low thirties.
    Black B7 Titanium - Sold
    APR93 | Carbonio | Vogtlands | RS4 sway | Abt quad-tip | Podi | BBS RCs w/RT-615s | RS6s w/W300s
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    i guess you got your water/meth set up with revo right? did you datalog or just go on what kmd's dyno said? i cant believe youre car is that low on wheel hp though. its gotta be more than that.........
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Registered Member Three Rings turbo4s's Avatar
    Mar 27 2006
    AUDI B7 S4 / MKV GLI
    that dyno suxs. 22-25% is the norm for awd dyno. Just put it this way if you are breaking the 270's hp range, you should deff be some where in the 220+'sawhp
    _______
    Artic White B7 S4 Fully Loaded
    Mods= Titanuim RS4 Grill
    Salsa Red MKV GLI Fully Loaded
    Mods= Revo Stage III KO4, Carbonio, AWE Full Exhaust, AWE FMIC, H&R spring & Sways, AWE Vent Guage,
    ECS Blacked Out Coners, ECS Snub Mount, KMD Fuel Pump, KMD Cam Follower
    Jun 26 2008
    New Jersey
    Quote Originally Posted by RedS-line View Post
    Yea even after the 2nd run we cranked up the timing to 8 and boost to 7 because my car was handling it fine.
    B7 A4.... 394awhp
    Jun 26 2008
    New Jersey
    Its how Louis J says it all depends on the dyno.
    B7 A4.... 394awhp
    Mar 19 2008
    Quote Originally Posted by eastwick897 View Post
    I thought you were already running boost 7? correct me if im wrong, but i heard that moving from boost 6 to boost 7 increases torque numbers but decreases peak hp a little. How did your pulls come out with boost 6?
    2019 S5 BO.SS
    2009 R8 6 Volt :)
    Veteran Member Four Rings Sal_B7's Avatar
    Dec 11 2007
    2005 A4 2.0T Quattro 6Spd
    San Diego, CA
    Dang i have about the same set up.. Might have to consider getting a GT28 hmmm....
    '05 A4 2.0T Quattro MT APR Stage 3
    2008 APR Holiday Giveaway Winner!! Thanks APR!!
    FRRG Southern Ring
    Xbox Live ID: Sqzn2zz
    Jun 26 2008
    New Jersey
    Quote Originally Posted by Sal_B7 View Post
    I'm using this for the exact same excuse lol
    B7 A4.... 394awhp
    Jun 26 2008
    New Jersey
    Less dude not by much but it was less.
    B7 A4.... 394awhp
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    wow... i have your mods, and im pulling 255 wheel, 290 motor, guess its just a freak then.. and i was running 7-7-9
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Senior Member Three Rings GhostSquadGarage's Avatar
    Jul 05 2008
    SLR32 \ IS300
    Is your car auto ?
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    Quote Originally Posted by GhostSquadGarage View Post
    Is your car auto ?
    Do things change for us tiptronic guys?
    Jun 26 2008
    New Jersey
    Is your car auto ?
    Nope..Manual. For the guys running revo I have a question. In first and second gear when your reall get on the car, does the boost spike to 20 and then go down to about 15 and hold there for awhile? I noticed my boost hold at about 21 real well when I'm in high gears but for the lower gears it'll fluctuate.
    B7 A4.... 394awhp
    Jul 05 2008
    SLR32 \ IS300
    Quote Originally Posted by 06B7audiA4 View Post
    I've never dyno'd a tip for more than 165awhp. I see the 6spd going for far more than that though.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    that is really low with the mods you have, maybe its the dyno
    Senior Member Three Rings gpultro's Avatar
    Oct 01 2008
    07 B7 / 07 CBR1000 / CAR LIFT
    new jersey
    there is no way you are at that to the crank what formula are you useing...
    if that was true i would be at 411 hp and im not i think i am at like 370 crank
    AutoSpeedPerformance
    GT3071r
    350 awhp on 93
    376 awhp on 104
    376/(.72)=516.xx Crank on stock block, FMIC and turbo back straight pipe. Great job ASP!!!
    http://www.audizine.com/classifieds/...?product=46657
    Jan 01 2008
    Long Island NY
    Greg u should be around 420 to the crank
    Jan 01 2008
    Long Island NY
    I put 220whp 255wtq down immediatly after 12 runs on the quarter mile tiptronic on a Dyno Jet in 3rd gear
    Nov 16 2005
    mass
    How are they figuring the crank numbers without actually pulling the engine and doing an engine dyno? Calculations based on drivetrain loss will be way off. The only number to worry about is wheel hp/tq
    2003 RS6
    had: 2006 A4 quattro M6 2.0t
    had: 2008 VW GTI 2.0t M6
    Established Member Two Rings cab7a4's Avatar
    Oct 09 2008
    Southern California
    wow that is really saddening that we can not break 200 with those kind of upgrades
    Jul 05 2008
    SLR32 \ IS300
    ^^You should see the baseline dyno for this car. Quite sad in itself.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by slingblade View Post
    Exactly. I don't care if you had a GT35R on that car and made 600chp, if you only make ~180whp, that's all you make.
    Congrats, now make more.
    Jan 10 2007
    VA
    ultimately full bolt ons on an A4 with a stock turbo will get you about a 20-30% gain in power. No matter which dyno you test it on, if you baseline first, then dyno after mods, you will see about that same % of gain. If you compare that gain to the stock crank power you end up with 250-270 crank horsepower. That's all these cars can put out with the K03. That also is in line with the ~ 14.00 second 1/4 mile times these maxed out K03 setups seem to produce.
    Jun 26 2008
    New Jersey
    Quote Originally Posted by gpultro View Post
    no formulas dude its whats on the sheet...
    B7 A4.... 394awhp
    Oct 01 2008
    new jersey
    ill have to look at my sheet next time i dyno after the build to see if it is on there i dont rem it being on there when i got the 320 but i might be mistaken
    GT3071r
    350 awhp on 93
    376 awhp on 104
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    Nice numbers. For comparison (and I have a B6, but it was on the same MAHA dyno): 244.8chp (180.9whp), 312.8 ft/lbs.
    Can you scan and post your dyno sheet? I'm curious to see the tq curve on the 2.0T...
    Dahlback | AWE | Milltek | Vogtland | H-Sport | Oettinger | Thule | OEM+
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    ahhh... it's "loses" not "looses"
    Senior Member Three Rings fromGMCtoAUDI's Avatar
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    Quote Originally Posted by AWDTURBO View Post
    Woohoo fwd ftw!!
