Results 1 to 40 of 40
    Sep 17 2008
    B7S4
    Ridgefield, CT
    center cluster display with RNS-E
    I successfully installed my RNS-E but I am not getting the directions on the center display above the steering wheel. Is there something else I need to do for that?
    2006 Silver S4 - Hotchkis RS4 HSport Sways - Euro RNS-E
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    Re: center cluster display with RNS-E
    you need to edit the settings with a VAGcom
    Sep 17 2008
    B7S4
    Ridgefield, CT
    so I need a VAGcom cable and software? Do you know the setting to change? Or should I just search for it here. Thanks for all the help ngng.
    Quote Originally Posted by stretchS4 View Post
    You need find use a Vag-com to recode a few things.
    Check this for a full guide...
    NSX JR
    If you want to come down to NJ i can do it for you...
    Veteran Member Two Rings Omar0022's Avatar
    Dec 12 2004
    Bay Area
    After my install and Vag setting I noticed the same thing. The way around it was to turn off your NAV and then turn it back on and then it will appear on the cluster.
    Sep 17 2008
    B7S4
    Ridgefield, CT
    Thanks, I will try both. The unit I bought, claimed to be VAGcom coded already.
    Sep 17 2008
    B7S4
    Ridgefield, CT
    Yikes, I didnt realize the VAGcom setup was so expensive. Is there anyone near southern Connecticut that has one?
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    there's a $20 ebay cable and free software that might help. It covers some basic stuff (headlight settings, removal of bing-bing-bing for seatbelt, activation of automatic windows/sunroof close/open via your remote key) but may not be able to adjust your navigation system settings.
    otherwise I think the full on setup is only $190 from RossTech....the $400 package is a bunch of bullshit you don't need.
    hey, good to see you picked up an RNS-E! I remember giving some tips and recommendations on the system a wee while ago.
    Where'd you get it?
    Sep 17 2008
    B7S4
    Ridgefield, CT
    I got it off of ebay, it came from Poland. I think its great. My wife has the myGig system in her Jeep and the RNS-E is much better. The interface on the myGig is awful.
    Im not sure what cable and software is the one I need. So I guess I can search for it. Would be sweet to find someone near me that has it. (and knows what they are doing)
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    Quote Originally Posted by Omar0022 View Post
    This is because you have the red DIS - which has a bug that Audi won't fix since they didn't sell A4s with the red DIS and the sat nav.
    But you still have to have the correct value in adaptation channel 62 of the instruments.
    Sep 17 2008
    B7S4
    Ridgefield, CT
    While I am trying to find someone with a VAGcom I can borrow, can someone verify that these are the correct steps I need to program?
    1. Select address "17-Instruments".
    2. Select "Adaptation - 10"
    3. Change the Channel Number value to 62
    Jun 02 2008
    was talking to a BMW dealer today...apparently the next generation of iDrive is going to be insanely good
    comes with an 80GB hard drive built in...no DVD nav, all HD based
    AND
    has dedicated 16 GB of space for music.
    AND
    has a USB port to upload/download music
    AND
    ipod hookup in glove with full screen menus/folders etc. (but who'll use it when the car is your ipod)
    you can even insert a CD, burn the songs to MP3 in your car's hard drive.
    final straw which I thought was awesome...your car connects to email. You can googlemaps directions on your computer at home, email to your car, and have the trip in there when you get to the vehicle
    Audi has some work to do!
    Jan 14 2007
    Hampshire, U.K.
    Nope that's not correct.
    1. Select address 17 - instruments.
    2. Select adaptation - 10
    3. Select channel 62 and read it.
    4. Add 4 to the value read in 3 and test it.
    5. Save it.
    Sep 17 2008
    B7S4
    Ridgefield, CT
    Quote Originally Posted by PetrolDave View Post
    5. Save it.
    Ok, so i add "4" to what ever the value is already? So if it was "5" in there I would change it to "9", test, and save?
    Sep 17 2008
    B7S4
    Ridgefield, CT
    This other string I found is saying to put a "21" in there. Whats the right #?
    http://www.audizine.com/forum/showthread.php?t=84841
    Registered Member Three Rings Buegie's Avatar
    Sep 18 2007
    e90
    Plenty of people have vag-coms, I'd advise you post in the regionals. Somebody from Danbury just let me use theirs but I imagine thats sort of far away.
    Sep 17 2008
    B7S4
    Ridgefield, CT
    Danbury is the next town over from me! Can you PM me the name of the member who let you borrow it?
    Hmm im also having this problem with the RNS-E install for a buddy. I open adaptation 10 and channel 62 as listed above. I had a value of 17 in the channel and added 4 for Navigation... Tested and Saved... However still couldnt get the NAV in the cluster...
    I tried to take the value of 16 out for the cluster and just put a value of 5 in the channel but still could not get the NAV to work in the cluster...
    Anyone have any insight?
    Jan 14 2007
    Hampshire, U.K.
    Both of us!
    The value without navigation is usually 17, so adding 4 makes 21!
    +1 = show radio information
    +2 = show phone information
    +4 = show sat nav information
    +8 = show telematics information
    +16 = needed by new clusters
    Jan 14 2007
    Hampshire, U.K.
    Quote Originally Posted by joeycuccaro View Post
    See my previous post...
    The other issue is that many people have found they need to eneter the correct value and wait 24 hours - something to do with sequence numbers of CAN bus messages IIRC.
    The other thing to remember if that if you have a red DIS (not a colo(u)r one) on a B6/B7 A4 there is a SW bug in the DIS that means to see nav instructions you have to:
    1) enter a destination
    2) turn on route guidance
    3) turn the RNS-E off
    4) turn the RNS-E back on, now the instructions will appear in the DIS.
    Note: this workaround ONLY applies to a B6/B7 A4 with red DIS.
    Sep 17 2008
    B7S4
    Ridgefield, CT
    So according to PetrolDave, this should have worked. Do you have the color or the red DIS? Did you wait 24 hrs to test again, per PetrolDave?
    He has a color DIS like mine. I guess were going to have to wait and see if it works.
    Thanks for the note Dave
    Veteran Member Three Rings charliemike's Avatar
    Jul 24 2008
    Virginia
    What the hell does a color DIS look like?
    Sep 17 2008
    B7S4
    Ridgefield, CT
    Ok, please let me know if it works. Or if you figure something else out.
    Sep 17 2008
    B7S4
    Ridgefield, CT
    joey - any news?
    joey - any news?
    Yes- Dave was correct. It took about 24 hours for the NAV information to show up in the cluster.
    Jul 24 2008
    Virginia
    Is this considered a color or red DIS?
    Quote Originally Posted by charliemike View Post
    Yes
    Its a color DIS
    Yes
    LOL
    6MT | Alcantara | 35% Tints
    Quote Originally Posted by JB_ImolaS4 View Post
    LOL
    Oops i didnt see the "red" part... thought he was asking if it was a color display... hahah
    Jul 24 2008
    Virginia
    Thanks Joey. Appreciate it!
    Jul 02 2008
    1999.5 A4 1.8T Quattro
    Danbury, CT
    I sent you a PM StretchS4.
    Anytime
    Lol... I do that all the time at work (answer a multiple choice question with "yes"). Tough to be a careful reader when you get tons of emails every day.
    Sep 17 2008
    B7S4
    Ridgefield, CT
    I getting ready VAG com this week and understand the +4 to get the NAV directions in the DIS. But, I just noticed that the RDS radio station info is not appearing there either. The station is, but not the text. I can see it on the RNS-E. Do I need to add a +1 also for this? Kinda wierd that the station is there and not the RDS info.
    If the station is appearing on the cluster than i would image the +1 digit is already in the coding. Perhaps its only a certain station your listening to that wont put the song text on the screen?
    When you go to code with the VAG give me a call. I will walk you through it. Its much easier to answer these questions if i have the value that is already stored in that adaptation.
    Sep 17 2008
    B7S4
    Ridgefield, CT
    Thanks Joey. Can you PM me your #?
    Sep 17 2008
    B7S4
    Ridgefield, CT
    Thanks to AEB A4 and Joey I now have the DIS working with the RNS-E! Very cool. Mine didnt take 24 hours to start working after the VAGcom. After a restart 20 mins later it was there.
    Awesome!
    Jul 02 2008
    Danbury, CT
    It was no problem. Let me know if you ever need to use it again.
