Results 1 to 6 of 6
    Sep 06 2007
    Bricktown, NJ
    new turbo - pressure loss?
    Hey guys - Just replaced my k03 with another unit (save money for later). Got everything hooked up after a bit of work, and it was working fine last night.
    I ran it a bit hard at wide open throttle a few times last nite - and only thing that happened was the charge pipe blew off, but that's because i forgot to tighten the clamp around it. Regardless, I go to drive it today, and it's acting a bit differently. It's not holding the pressure it was last night. I dont see more than a tad over 10psi and its struggling to get there. Also, I heard what sounds like an exhaust bolt rattling under the car under acceleration - any thoughts on what the problem could be?
    Thanks in advance
    edit: the car is a '98 a4 1.8tqm with GIAC stage 1 flash and nothing else
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    Re: new turbo - pressure loss?
    make sure nothing fell down that charge pipe. i had a bad experience once when i lost a tiny screw down the TIP.......
    Sean
    The New
    B7---GIAC--BBS--DDM--JHM+S4Exhaust--StaSIS SS--034--AudiUP--USP--RedEBC--IE--DrakesVC#12--B7S4 Brakes--StopTech--GFB DV+--
    The Old
    B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
    Sep 06 2007
    Bricktown, NJ
    nothing in the charge pipe. I've lost progressively more and more pressure every day. Barely pulled 5 psi last night. Think wastegate is busted. Not happy at all. This guy is going to get an ear full
    Sep 06 2007
    Bricktown, NJ
    bump- no one has any advice for me? My car sounds like it's really straining! It sounds like the wastegate to me but how could that be after 1 day worth of use?
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    check and see that all your clamps are tight. Do a pressure test to the intercooler pipes. if thats not it, check your N75 valve.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Sep 06 2007
    Bricktown, NJ
    N75 is brand new - didn't touch the inter cooler piping, all is tight. Weird though - ever since the charge pipe blew off (it ran fine that night) I've lost 5psi max output per day basically. 20psi the first night - 15psi the next day, 10psi on a highway drive two days ago, and it wont hit more than 5psi now. I suppose I'll pull the charge pipe off and see what I can do but i honestly highly doubt anything got sucked up into it.
    This wasn't an OEM k03 mind you - it was a cheap ebay k03 that was falsely advertised as a KKK. Don't worry, i made a stink about it.
