    Mar 14 2007
    MN
    B6 S4 wheels on a B5
    will this setup work with no mods and no rubbing?
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    Re: B6 S4 wheels on a B5
    Quote Originally Posted by mthomas141 View Post
    seriously? Look like 12 threads down......
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Unreal, I thought this was a joke.
    http://www.audizine.com/forum/showthread.php?t=247637
    Mar 14 2007
    MN
    well there is two different answers yes they will fit no problem and yes, but you need spacers
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    The consensus is that it will work without a spacer if you're on your stock, brake set up and your pads are not brand new. Otherwise, you will need spacers to clear the calipers.
    As for rubbing, that depends on what tires you're going to run and your drop. The stock B6/B7 tires are 235s which are a little wider than the 225s that are stock on our cars.
    There's some other threads on this as well, so I'll just close this for now.
    Current: B5 S4 Avant, F10 M5 (comp pkg), 14' Tundra (4x4), Lexus CT200h, BMW S1KRR
    Past: W212 E63, C6 A6 Avant, B5 and B7 S4 Sedans, FD RX7, a Civic Hybrid and 2 Beaters
