Results 1 to 8 of 8
    May 04 2007
    Ft. Lauderdale FL
    Unitronic 630cc file on an Eliminator Kit...
    Hey guys, just trying to see if anyone has run this setup, and if so how does it run?
    Thanks in advance
    2000-ATW-1.8M
    Mods: - Unitronic - Garrett GT2871R Elim - HighFlow Exhaust Manifold - TurboXS MBC - Bosch 044 Fuel Pump - Forge FMIC - Forge 007 DV -Aquamist WMI -Spec Stg 3 Clutch - Spec LWFW - 3" Turbo Back -Exhaust - 3" ATP Test Pipe - 034 Motor Mounts - 034 Tranny Mounts - Innovate Wideband - Neuspeed TIP - Carbonio Intake - Carbon Fiber Hood - H&R Cup Kit - H&R Spacers - APR Snub Mount - Diesel Geek Short Shifter - AWE Vent Gauge - 18x8 HP Evolution
    Veteran Member Three Rings kevin12's Avatar
    Jun 20 2007
    01.5 A4 1.8TQM
    South Jersey
    Re: Unitronic 630cc file on an Eliminator Kit...
    I'm looking for the same answer because thats the same turbo I'm looking to install soon.
    I'm curious because from what I hear, is that the uni 630cc file is the best of the their bt software?
    Current:
    17 Ibis White A3 2.0TQ S-Line
    01.5 Santorin Blue A4 1.8TQ 5-Speed
    Uni 1+, XS Power Exhaust, ST Coilovers, Forge DV
    99.5 Laser Red A4 2.8Q Tip Totaled RIP
    01.5 Casa White A4 1.8TQ Tip Current Parts Car
    08 Ibis White A4 2.0TQ Tip S-Line
    May 04 2007
    Ft. Lauderdale FL
    So nobody has an eliminator kit with the Unitronic 630cc file on it?
    2000-ATW-1.8M
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by djlindo2001 View Post
    They're just not talking.
    And FWIW, one of the guys on Vortex is running a 630cc file, but only b/c he's running E85 on his K03s (or was).
    As far as what I've read, the 415/440cc file is written specifically for the GTRS, GT28R and GT28RS, however I believe there's a version of the 630 file for the Elim turbos.
    Feb 27 2005
    North Wales, PA
    you might want to double check if they have a 630 file for your year.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    I know tons of guys running that setup on the CTAPP tuning..
    WOOOT post #3000!!!
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    May 04 2007
    Ft. Lauderdale FL
    Quote Originally Posted by Poopie View Post
    They do cuz i have it, having some issues that i covered in another thread though. So i wanted to see if anyone else has the setup working ok, or if its too much fuel for the Elim.
    2000-ATW-1.8M
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    IIRC the 415/440 tune is a 4Bar tune, vs your current setup w/ 3Bar and 630's. I don't think switching to a lower CC injector and tune will fix the problem.
    Plus the 2871Elim should be able to take advantage of the larger injectors.
    Did you do all the logs? What are your MAF readings @ WOT, and what MAF are you using?
