It is installed finished and she purrs. I get 20lbs of boost at about 4050 rpms.
Well the manifold finally arrived -
And a picture of the triplets
last but not least $550.00 in parts waiting to be installed
This is what my setup will consist of :
-GT3071R .63 A/R
-SPA Manifold
-Tial 38mm Wastegate
-Apexi AVCR Boost Controller
-Genesis 550cc Injectors
-Custom 3" Downpipe w/3" v band clamp
-Thermal Race Exhaust
Soon to be added (when money permits)
-AEB Head and manifold
-VR6 Throttle body
-Southbend Stage 5
-I.E. Rods w/ AEB pistons
And just for anyone that may need it in the future,parts ordered from ATP for the
OIL/COOLANT PARTS
(1) $ 12.00 ATP-OIL-028 OIL FEED ADAPTER
(1) $ 39.00 ATP-OIL-015 OIL FEED LINE 4FT
(1) $ 12.00 ATP-OIL-021 OIL INLET RESTRICTOR
(1) $ 29.00 ATP-FLA-019 OIL RETURN FLANGE -10 AN
(1) $ 42.00 ATP-OIL-019 OIL RETURN LINE
(1) $ 03.33 GRT-GSK-008 OIL RETURN GASKET
(1) $ 26.00 ATP-VVW-107 OIL DRAIN LOWER ADAPTER
(2) $ 18.00 ATP-FTG-004 COOLANT BANJO SET
(1) $ 22.00 ATP-FTG-003 COOLANT FEED BANJO
(1) $ 06.00 ATP-FTG -¼” NPT TO 6AN FLARE
(1) $08.00 ATP-FTG-021 BANJO FITTING
(1) $32.00 ATP-FTG-023 COOLANT FEED LINE
(1) $ 11.95 ATP-VVW-158 MANIFOLD GASKET
(1) $ 09.75 ATP-FTG-010 QUICK VACCUM TAP
(1) $ 06.00 ATP-OIL-007 ½” NPT TO -10 AN
(8) $ 01.15 MIA-FST-034 8MM HEX BOLT
(11) $ 59.00 ATP-FLS-028 V BAND ADAPTER MODULE
